[rebel-builders] trim control vs airspeed.
Post by Walter Klatt » Sun Feb 19, 2012 8:55 pm
What I am saying is the stick pressures with different throttle settings are
not sufficient to require changes in trim setting. In some airplanes that I
have flown, I have to trim differently for climb (full throttle) and
landing, as the stick (yoke) pressures are excessive if I do not.
I am not saying that there is no pressure, and I do know some that will trim
even a Rebel. But it is very slight in comparison to some other planes, and
not worth fiddling with for me. In fact, I never even notice it.
If I pull power back, I think I do push the nose down slightly to descend.
But since I actually have to think about it to tell you, just goes to show
how insignificant that pressure is. I can honestly tell you that I have not
adjusted my trim in flight for many months. That includes different
loadings, sometimes with a big baggage load.
And I have very little friction in my elevator control system. On the
ground, the elevator will fall to the stick forward position if unattended.
tjhickey@iowatelecom.net
Sent: Wednesday, August 31, 2011 2:28 PM
Subject: [rebel-builders] trim control vs airspeed.
Walter:
This confuses me.
You say that you do not have to change trim settings when you change
throttle settings.
Can you tell me what happens when you pull the power back from cruse? Does
the aircraft begin a descent and hold to the prior level cruse airspeed?
Or does it require you to push the nose over after you close the throttle?
Tim Hickey
Sent: Saturday, August 27, 2011 11:26 AM
Subject: Re: [rebel-builders] Re: [rebel-builders] And the saga
continues...Rebel #56 Build
If yours is not stable in pitch, you may need to adjust your elevator trim
slightly. With mine it is completely hands free, unless fuel/pax really
unbalanced, or non cruise flap setting. Can even fly feet off the rudder,
with the right power setting. My flap setting though, does change the roll
stability, I assume because of the prop wash, with full flaperons instead of
separate ailerons on the Rebel.
I actually like the near neutral stability in roll and pitch. I can take my
hands off the stick, to get a map, or sunglasses, and it will stay in
whatever attitude I had it. Also nice in steeper turns with little stick
pressure.
The only time I really have to pay attention to stability and rudder use, is
when I haul the canoe with Wayne's canoe loader. I am getting used to that
now, but it can be a little unnerving in turbulence.
I also really like not having to adjust my elevator trim every time I change
flap or throttle setting like in some airplanes.
I guess all airplanes are a little different, and there are compromises, but
sometimes it is just preference or what you are used to.
tjhickey
Post by tjhickey » Sun Feb 19, 2012 8:55 pm
Thanks, Walter.
I have been thinking about this for several days, now. Perhaps the next time
you go flying you could do a little experiment for me. While in cruse, and
properly trimmed to maintain altitude, note the airspeed, and then pull the
power back to a high idle. If you have a lycoming, say maybe 1100 rpm. Don't
touch the stick. Note what happens, and then perhaps you can tell me what
the aircraft did.
I have a Zenith CH300, and if I did as above, the aircraft would drop the
nose slightly, pick up a little speed, then the nose would rise slightly,
and bleed off a little speed, and this would continue for two more
iterations, with the final result being a steady descent at the original
cruse speed.
I have a (used) century auto pilot (wing leveler with Nav-Tracker) that
works quite well. When established at 90 knots on a localizer, I can fly at
2100 rpm until I intercept the glide slope. Then all I have to do is to pull
the power back to about 1700 +or- and the aircraft noses over and maintains
90 knots while tracking the localizer. I manage the glide slope by adding or
removing a little power. All the while maintaining the 90 knots.
If you would prefer to respond off line, you may email me at
tjhickey@iowatelecom.net, or just give me a call at 319 463-7047, home, or
319 795-2684 cell.
Thanks.
Tim Hickey.
Sent: Wednesday, August 31, 2011 4:49 PM
Subject: RE: [rebel-builders] trim control vs airspeed.
Walter:
This confuses me.
throttle settings.
Tim Hickey
pressure.
I was at the lake when I saw your email on my BB. So on my way home, I tried
what you suggested. I pulled the power down to idle, and let go of the
stick. It immediately dived down until it exceeded my original cruise speed,
and then slowed down a bit as the nose started to lift a little. However, I
started that descent at only 2500 ASL, and it didn't take long to get down
to 1000 feet (saw 2000 fpm down at one point), so that was the end of that
test.
But it did seem like it had a little positive stability, and it may very
well have maintained the original cruise speed on descent, if I had a little
more altitude to work with. And remember, I am on amphibs, with a lot of
drag, so not a great glide ratio. I also have the larger float angle now, so
that probably doesn't help either.
Someone on wheels should do this test. It would likely be more meaningful
than an amphib.
Sent: Sunday, September 11, 2011 1:46 PM
Subject: Re: [rebel-builders] trim control vs airspeed.
Thanks, Walter.
the aircraft did.
cruse speed.
319 795-2684 cell.
Thanks.
Tim Hickey.
Walter:
This confuses me.
throttle settings.
Tim Hickey
pressure.
Post by Craig Walls » Sun Feb 19, 2012 8:55 pm
I'm going up tomorrow. I will try this test. It'll fit in with my other "experimenting" nicely. Craig #207 10.4 hrs!
Date: Sunday, September 11, 2011 5:21 pm
home, I tried
cruise speed,
However, I
get down
of that
test.
may very
had a little
lot of
angle now, so
meaningfulthan an amphib.
Thanks, Walter.
next time
cruse, and
then pull the
rpm. Don't
me what
the aircraft did.
drop the
slightly,
original
cruse speed.
that
can fly at
is to pull
maintains
adding or
home, or
319 795-2684 cell.
Thanks.
Tim Hickey.
settings are
airplanes that I
will trim
planes, and
descend.But since I actually have to think about it to tell you,
just goes to show
have not
unattended.
Walter:
This confuses me.
throttle settings.
cruse? Does
airspeed?Or does it require you to push the nose over after you
close the throttle?
Tim Hickey
elevator trim
reallyunbalanced, or non cruise flap setting. Can even fly feet
off the rudder,
the roll
instead of
can take my
stickpressure.
rudder use, is
to that
time I change
compromises, but
So Craig, how is the flight testing going? Have you done your climb test
yet? My guess would be 2200 fpm solo?
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Craig
Walls
Sent: Sunday, September 11, 2011 6:53 PM
Subject: Re: RE: [rebel-builders] trim control vs airspeed.
home, I tried
cruise speed,
However, I
get down
of that
test.
may very
had a little
lot of
angle now, so
Thanks, Walter.
next time
cruse, and
then pull the
rpm. Don't
me what
the aircraft did.
drop the
slightly,
original
cruse speed.
that
can fly at
is to pull
maintains
adding or
home, or
319 795-2684 cell.
Thanks.
Tim Hickey.
settings are
airplanes that I
will trim
planes, and
just goes to show
have not
unattended.
Walter:
This confuses me.
throttle settings.
cruse? Does
close the throttle?
Tim Hickey
elevator trim
off the rudder,
the roll
instead of
can take my
stickpressure.
rudder use, is
to that
time I change
compromises, but
Walter,
I haven't pushed the limits at all, steep turns, full power climbs and descents, etc. I have been following the FAA test flight program pretty much. I have seen 1400 fpm with full tanks, me, and 60 lbs in the tail. That was at 75 mph. I'll get some numbers within a few weeks. We are going to Reno this coming week for the air races so no flying :( CW
Date: Sunday, September 11, 2011 8:35 pm
Subject: RE: RE: [rebel-builders] trim control vs airspeed.
climb test
Of Craig
Walls
my other
home, I tried
of the
cruise speed,
However, I
get down
end
of that
test.
may very
had a little
lot of
angle now, so
Behalf Of
Thanks, Walter.
next time
cruse, and
then pull the
1100
rpm. Don't
tell
me what
the aircraft did.
drop the
slightly,
more
original
cruse speed.
Tracker)
that
can fly at
do
is to pull
maintains
by
adding or
7047,
home, or
319 795-2684 cell.
Thanks.
Tim Hickey.
settings are
airplanes that I
that
will trim
planes, and
just goes to show
have not
On the
unattended.
Behalf Of
Walter:
This confuses me.
throttle settings.
cruse? Does
close the throttle?
Tim Hickey
elevator trim
off the rudder,
change
the roll
flaperons
instead of
can take my
stay in
little
stickpressure.
rudder use, is
used
to that
time I change
compromises, but
