The build manuals are available from the factory, on CD.
You are asking someone to break copyright by sending them
to you ....
The factory sells extended droop tips too ....
You can order only by email to:
Shipping@murphyair.com
It would be good to let them know that you are the new
owner, so they can keep records up to date ...
bobp@prosumers.ca
bobp@pattersys.com
http://www.Pattersys.com
responsibility of the reader.
On Friday 02 September 2011 14:50:52 marty.tibbitts@dcsol.com wrote:
Hi all, I recently acquired N768MM, a nice M14 Moose on floats.
However, the builder did not install the drooping ailerons and I am finding
its low speed performance a bit weak. I basically would like more lift,
and I understand that the drooping ailerons make a huge difference.
Does anyone have a PDF of the build manuals? Unfortunately the Moose
didn't come with the manuals and the previous owner is silent. If you
could email or yousendit to me that would be great. (mtibbitts@bossco.com)
Next, is there a wing tip extension that might be available?
Marty Tibbitts
