http://n254mr.com, search for "drain grommets". Cut holes in D shape
(assuming seaplane-type), apply 2-3 coats of Poly Tack under, 8-10 min
apart, apply drain, put dollar patch over top, a coat of pink, shrink patch,
especially edges, then 3 more coats of pink, then silver.
On Sat, Aug 20, 2011 at 9:49 AM, mike jones <mfjrebel007r@cogeco.ca> wrote:
Hi all
Does anyone have pics of their flap drains, poly fibre says to cover with
strip of fabric, I forgot to install and have sprayed the silver protective
coat on the flaps, do I know have to remove all of it to glue the drain on
with polytack
Mike#007
