Pro-seal repair preping
caltrac
Post by caltrac » Sun Feb 19, 2012 8:51 pm
6-29-11, Re the gas tank leak repairs: how is that the suggested repairs are
working without following the bldr man'l instruction of prepping the area with
the use of scotch bright and acetone..? Which I understand to be an
impossible task in a fully closed up wing-no way to get at the leak. Can Pro-
seal be applied to the outside of the wing..? And than painted over for
effect. Sloppy, maybe, but say just a little dab on the leaking rivet, or using
a bead on a leaking seam, instead of drilling out a rivet and causing a bigger
problem maybe and if that is the only way short of taking the wing apart than
why not..?
