6-26-11, I'm trying to make contact with G. Mohr for his machined pivot block
for the Rebel bungee gear. I've tried his email but they failed...! I tried
these two email's as suggested by other's but they didn't work.
(gtmohr@telus.net) (failed)and (gmohr@telus.net) (failed)
.?? Does anyone have a better email ..?? or ..?? Does anyone know if he is
still producing this item...?
Rebel's bungee gear/fuselage pivot has finally broken due to too
many "rough" field landing's and takeoff's, I guess. My gear has the 1" dia.
stub and broke at the bolt hole. (not strong enough), however I'm glad the
gear failed at that point and not some major airframe part. But I'm afraid
that I won't be able to buy a replacement part from the factory any longer as
my last venture with them was a six month's delay before giving up. So any
ideas in fabing a replacement would be a great help also. I've located some
AL 6061-T6 1"x 0.125" stock, so I just a little help with the final dimension's
or improved design if any. tks all.
