[rebel-builders] Fw: Wing Dihederal
Dick Wampach
Post by Dick Wampach » Sun Feb 19, 2012 8:51 pm
ONE DEGREE is correct. I used a digital level to obtain the accuracy needed
for making the set up. It is also critical to drill the spar and lift strut
squarely, not just by eyeball!!! For alignment. I recommend after reaching
the 1/2" inch diameter to step up by 1/64th in size to keep thing from
drifting and do the final 5/8" cut with a reamer. I did find all the manual
changes from 2500 to 3500 confusing and finally got past the confusion to
use the 5/8" bolt sizes and made the holes with a minimum clearance, this is
one place you don't want any extra movement. If I could have worked with a
zero clearance I would have, of a taper pin, but I did bolt mine together.
Dick Wampach SR-08 N331RW
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com]
Sent: Thursday, June 02, 2011 3:01 PM
Subject: [rebel-builders] Fw: Wing Dihederal
To: <mike.davis@dcsol.com>
Sent: Thursday, June 02, 2011 12:34 PM
Subject: Wing Dihederal
Can someone confirm the Wing Dihederal for a SR3500, super Rebel, is 1
degree.
Sent from my BlackBerryR wireless device
password "builder"
mtutt
Post by mtutt » Sun Feb 19, 2012 8:51 pm
Thanks, I also found the manual a little confusing but were on our way now.
