I have a 1/4"drive socket that I ground down so that it fits and use it only on those tough to get at studs.
Michael.Jones@snclavalin.com>
Sender:
mike.davis@dcsol.com
Date: Wed, 27 Apr 2011 15:20:29
To: <
rebel-builders@dcsol.com>
Reply-to:
Subject: RE: [rebel-builders] exhaust hangers
Since we are talking about exhausts, I cant find a tool to get onto the
exhaust lugs to tighten them, socket and wrenches can do some but
difficult to get at some of the studs, any suggestions
cheers
mike.davis@dcsol.com [mailto:
mike.davis@dcsol.com] On Behalf Of
Sent: April 27, 2011 3:17 PM
To:
Subject: Re: [rebel-builders] exhaust hangers
Rick.. I've never used that exhaust, but you'd want to adjust them to
where
you want them and then tighten them up. I'd think solid would be better
than
any chance of them swinging against something you don't want melted/worn
thru.
The other style is a ball socket that you adjust to where you want it
then drill for a stainless rivet to lock in place.
Did you get those floats slid back out into place on the spreaders??
rgreenwood@hotmail.ca>
To: <
Sent: Wednesday, April 27, 2011 2:01 PM
Subject: RE: [rebel-builders] Gord Mohr's Bushings - Bolt ?
Hello Wayne
It looks like I'm going to have to change my tail pipe hanger,oops
didn t
see that pic till you pointed it out.Do you know the proper tension on
bolts and springs for the ball joint.Should it be none moveable or
slightly moveable?
Good health to Jennifer,I'm sure all will work out well.
Rick
List archives located at:
https://mail.dcsol.com/login
Unsubscribe:
List administrator:
Unsubscribe:
List administrator:
Unsubscribe:
List administrator:
