To: "Murphy Rebel Builders List" <rebel-builders@dcsol.com>
Sent: Tuesday, March 15, 2011 10:08 PM
Subject: [rebel-builders] Before you install that rudder trim tab - STOP
Reading another forum on broken rudder pedal return springs on Super
Cubs......
...... got me to thinking about the numerous Rebels and Elites that I've
had
thru the hangar/shop over the years, that have arrived here sporting a
trim
tab on the rudder.
Before you make this ugly, forehead cutting mistake, that you'll regret
next
time you bend down and pick up the tail by the tail spring..
Lift the tail up and set it on a sawhorse, milk stool or what ever you
have
handy. Now grab the rudder in your hand and push it fully left... fully
right.. back to center.. did the cables stay tight or did they go slack??
Every airplane I've had come in here sporting a trim tab has had one
rudder
cable that goes slack (or a tail wheel friction issue). Improper spring
geometry or excess friction somewhere in the system that doesn't allow the
rudder pedal (and it's spring) to maintain cable tension. This is the
generally the cause for the need of a rudder trim tab.. not an issue of
control surface itself, but one rudder pedal return spring pulling the
cable
tight and the other one not doing so.
So before you rivet that mess on the tail... check out the cause. Also
remember when you have the cables running smoothly you can also trim for
any
minor issues by tightening the spring on one side. Better there than the
drag (or cut forehead) of a trim tab.
When you go to floats/amphibs..... if you find you need a bit of rudder
trim
just adjust a water rudder slightly in the opposite direction and it will
move your air rudder for you, for feet off "ball in the center" flight!
