Curt Martin
N97MR
Sent: Thu, Feb 17, 2011 3:26 pm
Subject: RE: [rebel-builders] RE: [rebel-builders First Flight...has happened!
Congratulations Jesse
should be joining you this summer. Just applied for my final inspection.
ale
rom: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Jesse
enks
ent: February-16-11 10:42 AM
o: Builders list
appened!
hanks guys, well as promised it is poring today, so glad I got to fly
esterday otherwise I would be pulling my hair out. Now I can concentrate on
ixing my squaks. Are there any of you out there that have had good luck
ith a static mast under the wing?
Subject: Re: [rebel-builders] RE: [rebel-builders First Flight...has
appened!
Date: Wed, 16 Feb 2011 09:23:09 -0600
Look forward to your you-tube and info. Hope to be sending out a similar
mail some time this summer.
Charlie E.
To: "Builders list" <rebel-builders@dcsol.com>
Sent: Tuesday, February 15, 2011 11:14 PM
Subject: [rebel-builders] RE: [rebel-builders First Flight...has happened!
andingIt flies really nice, just like everyone says. I did a nice wheel
uselage.with a light crosswind, one wheel at a time. Had a wicked tailwheel
shimmey when it touched down and it wouldn't stop until I was at taxi
speed, so that was a bummer. Makes me glad I didn't 3 point it though. Iprobably like everyone else who put static ports on the forwardalso have a nasty oil leak to track down and my airspeed is sluggish,
uckI guess I will try a static mast under the wing. Does that seem to work
well?
Looks like I have a few days work before I can fly again. I also have totoday's flight, complete with a cardboard section around thefinish the wing/fuselage fairings as I just had them duck taped on for
LE/windshield. That's OK because it is supposed to rain for a few days,
and I new this afternoon would be my window of opportunity, thus the
ithtape and cardboard to get me airborne.
I loaded 80 pounds of wood stove pellets and had 20 gal fuel for a CG ofone notch for takeoff and landing. That seems very adequate for a first14.5. The handling was just great. Ken I took your advice and just used
time in the airplane, although I think I may have actually taken off
henone notch negative by mistake. My flap handle is not labeled yet and
tI went to retract the flaps at about 1,000' I seem to remember pulling
ndback one notch to neutral. Who knows now, and it took off and climbed
great either way.
Thanks.
Date: Tue, 15 Feb 2011 08:24:46 -0500
Subject: Re: [rebel-builders] I'm airworthy! - First Flight
Ahh the wheel landing question! Probably whatever you are most
comfortable with Jesse as guys have different preferences. I ask new
guys to use one notch of flaperon for the first takeoff and landings
heto try for a 3 pointer. It is a bit easier to get the tail down with
less flaperon. I think Bob always uses full flaperon though. Full
flaperon slows the stall 10% but that is only about 4 mph.
I've alway aimed for three pointers for better directional control with
the tail down. Unfortunately my wing is not stalled with the tail on
econdsground even with full flaperon. I've had occasions where several
onditionsafter the tail was down a strong gust threw me back in the air. So I've
come to appreciate the merits of wheel landings in very gusty
as long as the wind is down the runway. Full flaperons with some power
and quickly dumping (retracting) the flaperon at touchdown works well
for me with wheel landings in gusty conditions. However I don't like
wheel landings with a crosswind or on short rough strips so I rarely do
them.
Have fun you'll enjoy the rebel.
I always take off with full flap but
On 2/14/2011 11:09 PM, Jesse Jenks wrote:Thanks guys, Ken, would you say wheel landing or 3 point for the
first few, and one notch for takeoff and landing? BTW I fly a DC-3
for a living, not saying I won't screw up, but I do feel qualified to
make the first flight. That takes me back to my first question
though, because all landings in the DC-3 are wheel landings so at
this point that is what I am more comfortable with. First engine
start today went great, except no tach reading on the Dynon :( and
small oil leak from somewhere. It was almost more thrilling putting
fuel in the tanks for the first time and hearing it hitting the
bottom of the tank. No leaks yet but only put 10 gal each side and I
have 30 gal tanks so it may be a while before I get to test all my
proseal.
Curt Martin
N97MR
ale
enks
o: Builders list
appened!
appened!
Charlie E.
well?
great either way.
Thanks.
them.
proseal.
