Use washers to insure a tight fit. You won't wear the bolt hole in the
stinger; you will, however, and almost inevitably regardless of how firm you
washer up the stinger to the FUS-360 (right # ?) mount, end up with
elongated holes in the FUS-360 holes. So while you're at it, install
nutplates/anchor nuts on the back side of each FUS-360 (right/left parts) so
it's easier to replace them later.
Or, create your own custom front stinger mount (as some have done) or buy
Dale Fultz's custom front mount.
Ted
Beall
Sent: Thursday, December 30, 2010 10:21 AM
To: new list server
Subject: [rebel-builders] Preventing Moose/SR stinger side-to-side movement
Guys,
Quick question: I have a custom stinger purchased from another builder a few
years back. It's 1 inch in diameter, so there is a slight gap either side of
the stinger up in the tailcone where it mounts.
What have others done to take up this gap? I was thinking either delrin
spacers or some sort of rubber cushion. Thoughts and/or suggestions?
I can see if you don't prevent the side-to-side movement it will eventually
wear the bolt hole on the stinger.
Thanks, -Jason
