[rebel-builders] Rear drag brace failed
Garry Wright
Post by Garry Wright » Sun Feb 19, 2012 9:31 pm
It is pretty straight forward to rework that drag strut. If it is broken and
you fab a new one, make sure it is the same length as the right one. Most
builders would call this a minor job and expect to spend a few hours sorting
it out. You should check for other damage if the main strut has been flexing
backward significantly. Also, identifying why the drag strut failed would be
a wise precaution. Taxiing in gusty cross winds would not normally be
expected to cause this sort of thing. At a root level, something else was
wrong and the wind maybe caused an incipient failure to occur right then. If
you understand it, you will have a lot more confidence that it won't happen
again after you have fixed it. Just start taking it apart one step at a
time. Probably wise to support the aircraft and avoid collapse forward or
aft of the main gear. If you ever had an erector set of a meccano set, you
can do this.
Garry
On Sat, Jul 24, 2010 at 7:14 PM, <caltrac@dcsol.com> wrote:
7-24-10, My '95 Rebel with bungee gear that I purcased flying without any
plans had a left rear drag brace fail during a hard landing, in gusty,
xwind
conds. No outward damage can be seen. The next day while I was taxing I
heard what sounded like I was dragging a tin can, I only was able to
discover
what the noise was because I saw the left tire moving to the rear as I
applied brakes and than forward with brake release. I presume the blind
rivets attaching the brace sheared. How do I repair this?? What are the
steps? Where do I get parts if required? Is this a big job with many
steps or
rather minor? My drill is ready. Tks one and all. caltrac@frontier.com
Curtis Langholz
Post by Curtis Langholz » Sun Feb 19, 2012 9:31 pm
Without plans it can look complicated. Taking the fairing off the gear would give you a better idea of what is moving or failed. It's hard to presume what kind of damage or what is causing the movement without further inspection. The original builder may not have put inspection holes where you need them but you can always add them where necessary.
Curtis
Date: Sat, 24 Jul 2010 17:14:55 -0800
Subject: [rebel-builders] Rear drag brace failed
plans had a left rear drag brace fail during a hard landing, in gusty, xwind
heard what sounded like I was dragging a tin can, I only was able to discover
steps? Where do I get parts if required? Is this a big job with many steps or
The New Busy think 9 to 5 is a cute idea. Combine multiple calendars with Hotmail.
http://www.windowslive.com/campaign/the ... P:042010_5
