the top rear extending farther aft rather than adding the "float fix"
bulletin doublers that the bulletin says to do on all Rebels. I don't
know whether the originals had the 5 degree bend but you will need the
bend as I recall.
Roland Kriening wrote:
Could someone confirm that Fus 9L is different in shape than Fus 9R. These
are the triangular pieces forward of the doors. They both have the forward
bend (for the windshield I assume) but the Fus 9l is larger and has a 5
degree bend one inch from the door attach point. The fus 9r is completely
flat other than the forward bend. Logic seems to tell me that these parts
should be the same shape, just reversed ??? Plans make no mention of the
difference. I hope this is not yet another mismatched part from the early
kits.
Roland
R56
Cabin almost complete, just doing roof.
