[rebel-builders] windshield retainer screws
Jones, Michael
Post by Jones, Michael » Sun Feb 19, 2012 6:03 pm
I have same situation on my widshiel and don't know what to do with it
Mike#007
Ron Shannon
Sent: February 24, 2010 11:33 PM
Subject: [rebel-builders] windshield retainer screws
The good news is the windshield is mounted and generally looks great,
with
one exception. I'm using the factory-provided dual flanged metal strips
for
the side and top windshield retainers, with the wide flange to the rear,
screw holes through the wide flange. The screw heads are at quite an
angle
to the rear flange, which is itself at an angle to fuse, of course.
Because
they're at quite an angle, the screw head edges are only loading the
forward
side of the wide flange bearing surface.
Any suggestions for getting the screw heads to sit flatter on the
flange? I
have seen this same configuration on other Rebels where the screw heads
seem
to draw down quite flat on the rear flange, but haven't figured out how
do it. (I have a hunch this shouldn't be a mystery, but concocting
mysteries
where there shouldn't be any is one of the few things I do well.)
With regular head screws (i.e., not truss head) on top of nylon washers,
head-to-flange angle looks a little better, but the only other option I
can
think of that might work would be to custom bend a Z-step retainer like
some
others have used.
254R
Jesse Jenks
Post by Jesse Jenks » Sun Feb 19, 2012 6:03 pm
What about just sanding some thick nylon washers to the same angle as the retainer?
Subject: RE: [rebel-builders] windshield retainer screws
Date: Thu, 25 Feb 2010 15:43:00 -0500
Mike#007
Ron Shannon
with
for
angle
Because
forward
flange? I
seem
mysteries
can
some
others have used.
254R
Hotmail: Powerful Free email with security by Microsoft.
http://clk.atdmt.com/GBL/go/201469230/direct/01/
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 6:03 pm
The use of "wedge washers" is an option, whether custom made by the builder,
or purchased. I think metal ones are available commercially, though they're
not cheap. I'm not crazy about the look, but it's an option. Changing to a
custom Z-step retainer is also an option -- probably where I'm headed with
this if there's no way to use the factory double flange retainer with
machine screws without an angle problem.
With the factory provided double flange metal retainers, I have installed
nutplates which do, of course, tend to hold the machine screws pretty
perpendicular to the fuse. But I assume people who have used machine screws
with separate washers and nuts on the inside must have the same issue, if
not on the outside at the wide flange, then on the inside. An inconvenient
angle has to be compensated for somewhere -- if the factory bent flange
retainers are used with machine screws. (Sheet metal screws or rivets may be
able to maintain some grip while being a bit off kilter to the hole --
though it doesn't seem like a good idea.)
Bottom line: What have others who have used machine screws with the factory
double flange retainers done about the angle issue? Has it not been an issue
and if so, why not? What am I missing? Have they put up with or accepted an
angle in the fastener face somewhere, whether outside at the screw head, or
inside at the washer? Or something else. I know some people have managed to
get their screw heads flat against the already angled wide flange, but don't
know how.
254R
retainer?
Post by Ken » Sun Feb 19, 2012 6:03 pm
I made new retainers for the side of the windshield as MAM's were never
going to look correct to me.
On the top of the windshield I used MAM's part but I put the screws
through the center of the retainer. ie not through the wide or narrow
flange. Actually I guess they were stainless 6-32 bolts and nylock nuts
rather than screws but screws would seal out water better. I do recall
futzing with some adhesive foam strips under the retainer to help even
out the angle but it worked out OK.
Doesn't help you much but you asked...
know how.
254R
retainer?
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 6:14 pm
Thanks, Ken. I have pictures of the screw heads drawn down nice and flat on
Ducky's retainers, among others, so it's interesting to hear what you did.
For the top retainer, I did make a second, slightly wider double flanged
piece so I could put the screws in the center section -- essentially the
same as you did for that. However, doing the same at the sides is
problematic at this point because I'd still like the total width of the side
retainers to line up with the fiberglass retainer that's already installed
below.
One reason I didn't put the holes in the center flat section on the sides in
the first place was that research in the archives seemed to indicate that
was the best location. In fact, for the windshield to make a 1" overlap of
the A frame (as specified in the manual (though mine is already a bit less)
and still line up the front line of the retainer with the forward edge of
the A frame (nicer look) the only place available to put the holes aft of
the acrylic is the wide flange. If I had placed them in the center section,
even as far back as possible, the retainer would have had quite a bit less
coverage over the acrylic -- maybe only 5/8" or so -- and I was not keen on
reducing the retainer's coverage of the acrylic that much.
The idea of putting something under the wide flange may have merit. "Except"
for the added weight (What's another couple of ounces? Right.) maybe a
narrow strip of 1/8" bar stock would work well. Otherwise, making some
Z-step retainers is probably the best solution in my case.
254R
On Thu, Feb 25, 2010 at 6:17 PM, Ken <klehman@albedo.net> wrote:
builder,
they're
with
screws
inconvenient
be
factory
issue
an
or
don't
know how.
254R
retainer?
Ron Shannon
Clarification: "...research in the archives seemed to indicate that the wide
flange was the correct location for screws."
below.
in the first place was that research in the archives seemed to indicate that
"Except" for the added weight (What's another couple of ounces? Right.)
maybe a narrow strip of 1/8" bar stock would work well. Otherwise, making
some Z-step retainers is probably the best solution in my case.
254R
Ron Shannon
To wrap up from here at least....
The real complication with fixing the screw-head-to-side-retainer angle was
aesthetic, namely, to line up the retainer bottom with the already trimmed
fiberglass retainer. If that hadn't been trimmed already, I could have just
made a wider retainer, with screws through the flat, center section. There's
a lesson there somewhere. One I should have learned dozens of times before
this.
Ken's comment about putting something underneath the rear flange inspired me
to try adding a 1/8" x 1/2" aluminum bar spacer underneath -- which has
worked out very well. There is still a slight angle between retainer and
screw head, but with these relatively light loads, not enough to be a
concern, much less look odd. Even that may disappear as the butyl sealant
tape under the side edge continues to compress.
Aesthetically, from the rear the junction with the fuse looks a little
beefier, which I sort of like. Even though the retainer stands off the fuse
a little more than before, it actually joins the fiberglass retainer a bit
better. Likewise, with the rear flange raised 1/8", the (foam
protected) forward flange has a more secure grip on the windshield. Probably
the "only" downside is a little weight (2.5 oz.) and time.
Wow! I might have built it this way in the first place if I'd thought of it!
:-) [Ed.: The delusional power of positive thinking.]
Thanks to all for the help.
254R
