[rebel-builders] rivets in AIL-27
Jeff Micheal
Post by Jeff Micheal » Sun Feb 19, 2012 5:46 pm
Hi Kevin,
Your AC Kit must be of the older generation. What is your Serial Number?
The AIL-27 part of the newer generation actually have five (5) holes in
them.
If I may suggest, it's best if you can give as much information/details
about your question as you can; such as a specific page or figure in the
build manual that your working on. You're pretty much guaranteed to get a
reply to your question, otherwise it can sometimes be left open ended.
Jeff
On Sat, Nov 21, 2009 at 7:41 PM, kevin curtis <kcs1911@yahoo.com> wrote:
I am very new to this, my first plane and all. The brass bushing AIL-27 has
four holes, but the plans say to rivet it on with three. Which hole am I to
leave?
Yours, Kevin
snowyrvr@mtaonline.net
Post by snowyrvr@mtaonline.net » Sun Feb 19, 2012 5:46 pm
Hi Kevin,
Welcome to the group! Jeff's right; depending on which kit you have, older
or newer, the number of holes vary in the AIL-27 flange. No matter which
you have, though, they all get cs rivets.
If you do have an older kit (like me, #207)it would help you to have the
newest copy of the manual. I have found myself going back and forth
between the two as I've built. If you want, contact me email direct and I
can help you with some other stuff I've learned regarding old vs new.
Craig snowyrvr@mtaonline.net
Original Message:
Date: Sat, 21 Nov 2009 19:41:14 -0800 (PST)
Subject: [rebel-builders] rivets in AIL-27
leave?
