and a Sensenich 74x53 ( just had the prop shop twist a 56 to 53) I get great off the water
performance and cruise 90 kts @ 7.8 gph or 100 kts @ 9.0 gph. Put a JPI fuel flow in
coupled to a Garmin 496 so I know exactly how much fuel I have when in the "bush" in
NW Quebec. I just love the Rebel, best A/C I have ever owned ( of 10). You will
enjoy your bird, I am sure. Bob Cressman 331R
Sent: Fri, Nov 13, 2009 6:18 pm
Subject: Re: [rebel-builders] RE: =?ISO-8859-1?Q?Re=3A_=5Brebel=2Dbuilders=5D_He
Bernard, if it is Sensenich, get the 74 X 54 two blade metal prop. Both the 150
hp and the 160 hp 320 Lycomings perform best with this prop when on amphibs. Do
not get the 74 X 56 inch pitch prop as there is a big loss of performance
compared to the 54 pitch. Your take-off, climb and top speeds will be better
with the 54. And there will be no loss in cruise (just slightly rpm) or fuel
efficiency.
I know this from many hours of flying side by side with other planes with these
different props, so this is from real life experience, not theory.
Date: Friday, November 13, 2009 1:58 pm
thank you Jeff,
I read with pleasure what you've written, especially since it's
rather good
news.
Can you tell me what propeller should be better for an
amphibious Elite, I
think a senssenich, but for which O 320 A2B
Bernard
On 11/13/2009 10:45 AM, westcoastkitplanes@gmail.com wrote to
rebel-
builders:
-> Hi Guys,
-> To the best of my knowledge (which is sometime good), there
is only one
cowl
-> (fiberglass) for the Elite and Rebel. The factory
(MAM) did a change up a
-> few years back to make one cowl fit both applications.......
Elite and
-> Rebel.
-> Cheers,
-> Jeff
-> On Fri, Nov 13, 2009 at 10:28 AM,
<bernard.liagre@dcsol.com> wrote:
-> > Hi Dennis
-> > thank you for your reply
-> > you confirm that there are specific caps for the Elite
-> > my engine is a 0 320
-> > Bernard
-> > On 11/13/2009 8:12 AM, croydonmac@gmail.com wrote to rebel-
builders:-> >
-> > -> Hi Bernard
-> > -> Be careful that you get the newest model of cowl for the
elite not a
-> > -> rebel cowl if you are using the O-360 thay are different
and when
-> > -> fitting made sure you make the inlet openings as large
as possible and
-> > -> make sure you have a large anofe exit area.
-> > -> Dennis Finley
-> > -> Elite Amphib C-FDYF
-> > -> 2009/11/13 <bernard.liagre@dcsol.com>:
-> > -> > Hello All,
-> > -> > I am on this list for several days, I read your
messages, and I must
-> > say
-> > that
-> > -> > from where I am, it feels good.
-> > -> > I built an Elite No 801, I am based in Biscarrosse in
France and
-> > outside a
-> > small
-> > -> > group of people, I feel very alone and far.
-> > -> > I share the same problems as many of you and I have
many
technical
-> > issues
-> > -> > and the parts you have.
-> > -> > I should not have been able to join Murphy in recent
months, and
-> > thanks
-> > to
-> > -> > you, I understood why.
-> > -> > ÿÿI have not come on this site to complain because I
can
understand the
-> > -> > difficulties faced by Murphy and I will retain their
willingness to
-> > help
-> > builders
-> > -> > complete their aircraft.
-> > -> > in France there is little seaplane and I fell in love
with the Elite
-> > for that. I
-> > -> > hope to fly with my Elite Floats and hopefully will
have enough for
-> > that
-> > (if my
-> > -> > wife has not left the by) ... I'm joking
-> > -> > Question: I want to buy engine cowls for the Elite, is
that someone
-> > can
-> > tell
-> > -> > me if they agree Rebel
-> > -> > thank you
-> > -> > Regards
-> > -> > Bernard
-> > -> > ÿÿList archives located at: https://mail.dcsol.com/login
-> > -> > ÿÿusername "rebel" password "builder"
-> > -> > ÿÿUnsubscribe: rebel-builders-unsubscribe@dcsol.com
-> > -> > ÿÿList administrator: mike.davis@dcsol.com
