[rebel-builders] Moose/SR tailwheel
Post by Wayne G. O'Shea » Sun Feb 19, 2012 5:41 pm
I have a Scott 3400 and an SR tailwheel under the bench. I'll have a look
tomorrow night.... after I'm done Muskie fishing for the day..
To: "new list server" <rebel-builders@dcsol.com>
Sent: Wednesday, October 28, 2009 11:14 PM
Subject: [rebel-builders] Moose/SR tailwheel
Guys,
Does anyone know if any other tailwheels are compatible with my Murphy SR?
In other words, are the two-bolt attach points on the Murphy produced
tailwheel the same spacing as, say, a Cessna 180-185 tailwheel
Thanks, -Jason
Ted Waltman
Post by Ted Waltman » Sun Feb 19, 2012 5:41 pm
Part of the answer is in whether you have the hollow tube stinger with an
outside diameter of 1.0" or the newer solid stinger (more common to Cessna
for instance) that is 1.0625" in diameter (1 1/16").
Ted
Beall
Sent: Wednesday, October 28, 2009 9:15 PM
To: new list server
Guys,
Thanks, -Jason
Jason... the SR tailwheel yoke I have in the shop is predrilled with a 1.25"
c/c on the two mounting bolts. The Scott 3400 tailwheel I have under the
table is the same! So order up one of those bushwheel tailwheels from Wup
and have at 'er !
Like has been cautioned though.. check your diameters. The AD modified 3400
tailwheel and stinger on a 185 is 1 1/8" diameter. The old ones were 1"
(like I have under the bench).
Sent: Wednesday, October 28, 2009 11:18 PM
Subject: Re: [rebel-builders] Moose/SR tailwheel
Guys,
SR?
Thanks, -Jason
Jason Beall
Post by Jason Beall » Sun Feb 19, 2012 5:41 pm
I have both! -Jason
--- On Thu, 10/29/09, Ted Waltman <ted@vafm.org> wrote:
[quote]From: Ted Waltman <ted@vafm.org>
Subject: RE: [rebel-builders] Moose/SR tailwheel
Date: Thursday, October 29, 2009, 1:00 PM
common to Cessna
Ted
On Behalf Of Jason
Beall
To: new list server
Guys,
with my Murphy SR?
Murphy produced
tailwheel
Thanks, -Jason
Jason Beall
Thanks Wayne and Ted. -Jason
Date: Thursday, October 29, 2009, 2:39 PM
have under the
tailwheels from Wup
and have at 'er !
AD modified 3400
ones were 1"
the day..
Guys,
SR?
the Murphy produced
180-185 tailwheel
Thanks, -Jason
Jeff Micheal
Post by Jeff Micheal » Sun Feb 19, 2012 5:41 pm
Wayne / Jason,
The tail wheel swivel (yoke) that you have Wayne w/ 1.25" c/c sounds like
its for the Elite and/or the earlier SR2500. If I recall correctly the tail
wheel swivel for the SR3500/Yukon has a mounting spacing (two bolts to
stinger) of about 2" and designed heavier.
Like always, check parts to see if any changes or updates have been done
over the years.
Jeff
On Fri, Oct 30, 2009 at 8:44 AM, Jason Beall <super_rebel131@yahoo.com>wrote:
I have both! -Jason
common to Cessna
Ted
On Behalf Of Jason
Beall
To: new list server
Guys,
with my Murphy SR?
Murphy produced
tailwheel
Thanks, -Jason
Yes Jeff.. the one I have here is from an earlier SR..
From: "Jeff Micheal" <westcoastkitplanes@gmail.com>
Sent: Friday, October 30, 2009 1:59 PM
Wayne / Jason,
tail
over the years.
Jeff
I have both! -Jason
common to Cessna
Ted
On Behalf Of Jason
Beall
To: new list server
Guys,
with my Murphy SR?
Murphy produced
tailwheel
Thanks, -Jason
