[rebel-builders] Derlin bearing block fit
Post by Ken » Sun Feb 19, 2012 5:41 pm
I sanded off the paint and still had to sand the delrin blocks as well.
I don't believe the movement will wear looser in service but the Crown
brand silicone spray may help a little. Some of us also reinforced the
bottom of the horizontal bulkhead with a piece of stringer or angle left
to right. That is to keep the bulkhead from flexing down which may cause
some binding on the CC-68 delrin bearings when the rudder cables are
tensioned.
Joel Jacobs wrote:
Hi,
I've been working on the elevator controls where I'm mounting the
CC-68 in the RP-13 bearing blocks on the aft horizontal bulkhead. The
bearing blocks are a really tight fit. So, do I just enlarge the
holes in the bearings or should I start by removing the paint on the
CC-68 where it goes into the bearing. Does the paint wear off anyway?
I guess what I want to avoid is enlarging the bearing for a good fit
and then having the paint wear off and making the fit to loose. I'll
be having the same issue with the rudder pedals.
Thanks much,
Joel
Richard Wampach
Post by Richard Wampach » Sun Feb 19, 2012 5:41 pm
On my Moose I scraped away the excess material until I had smooth movement.
I did this for both rudder tubes about 7/8" and elevator torque tubes about
2.0" diameter's. I did remove the paint from the steel tubes and polished
them with very very very fine emery cloth.
I used a single edge raiser blade to remove material where it was a bit too
thick, I feel that sanding would leave a rough surface, I wanted a "window
glass smooth surface". This was the same procedure my grandfather used back
in the days of early automobile engine repairs when it was necessary to pour
a Babbitt bearing then scrape away the excess material to have a proper oil
clearance on a crankshaft.
By doing it this way I did not have any fine slivers of delrin to cause
interference, or make a change in the friction at these bearings.
My manual insists NO LUBRICATION on the delrin
Dick Wampach SR-108 N331RW
Sent: Saturday, October 24, 2009 7:12 PM
Subject: Re: [rebel-builders] Derlin bearing block fit
tensioned.
Joel Jacobs wrote:
Hi,
be having the same issue with the rudder pedals. Thanks much,
Joel
password "builder"
Dale Fultz
Post by Dale Fultz » Sun Feb 19, 2012 5:41 pm
I could never get the fit I wanted with the delrin bearings scrapped them
and made new ones out of aluminum after fitting sent away had coated with
teflon to make a lifetime slippery surface. Made a tighter fit also when
mounting to the floor.. Dale N269DF SR-033
Jesse Jenks
Post by Jesse Jenks » Sun Feb 19, 2012 5:41 pm
I used a rotary file in the drill press and took a few passes around the circumference of each block. worked great.
Date: Sat, 24 Oct 2009 22:12:07 -0400
tensioned.
Joel Jacobs wrote:
Hi,
Thanks much,
Joel
Windows 7: Simplify your PC. Learn more.
http://www.microsoft.com/Windows/window ... en1:102009
Joel Jacobs
Post by Joel Jacobs » Sun Feb 19, 2012 5:41 pm
Wow Dale, sounds like you took care of that problem for good! I can
see why you did that, after getting mine just right I bolted them down
and the material deformed so much it got real draggy. If I tighten the
bolts just till the slop is gone and maybe just a tad more then it moves
just fine. I'd like to have the bolts tighter but I don't see how with
the delrin blocks.
Joel
