[rebel-builders] Moose - control deflection angles/measureme
[rebel-builders] Moose - control deflection angles/measurements
Post by Bob Patterson » Sun Feb 19, 2012 5:37 pm
Thanks Ted !
Sorry everyone - I had another run at the archives, and found
Dick's email with ALL the answers !
Chapter 12 Controls revision dated 3/3/2006--Moose Control Deflections
covers this info for a SR-3000, & SR-3500, differences are in the air
speed markings.  The Rebel and Elite are probably different.
Here are the SR- Control Deflections in Degrees of travel:
Flaps                   1st Notch-13*
                        2nd Notch-26*
                        3rd Notch-39*
Ailerons                Min Up-12*
                        Min Dn-12*
Elevator                UP 25* to 28*
                        Dn 12* to 15*
Elevator Trim   Nose Up 14*     I take this to mean airplane nose up-Tab
down
                        Nose Dn  4*
Rudder is not listed but---limit Max travel so it will not contact the
elevator in any position.  (nominally - 25 degrees L & R)
What a treasure this site is ! Thanks again Mike !!
bobp@prosumers.ca
http://www.PattersonAeroSales.com
responsibility of the reader.
On Friday 09 October 2009 00:49, Ted Waltman wrote:
Bob,
Yes, all the control deflection angles/measurements are in the manual.
Now, of course, not all in one place <sigh> but they are all still there.
I can look them up if you need them right away. I do remember that he
rudder is 25* side-to-side. Can't remember the others...
Chapter 12 has quite a few, but there are a couple buried elsewhere. For
instance, I think the rudder one is elsewhere.
Ted
Patterson
Sent: Thursday, October 08, 2009 6:33 PM
Subject: [rebel-builders] Moose - control deflection angles/measurements
Hi All !
We recently had a round of emails on angles for the Rebel ....
Does anyone have the control deflection angles/measurements
for the Moose ??? Is it in the manuals ???
Had a call today asking ....
