[rebel-builders] Re: Cooling with the speed cowl
Hans Kuck
Post by Hans Kuck » Sun Feb 19, 2012 5:36 pm
Hi Walter, thanks for the helpful info. How do I get into the archives???I
have a 2" spacer. As you say temps are a problem in the climb
cheers
Hans
640E
On Thu, Oct 1, 2009 at 8:13 AM, WALTER KLATT <Walter.Klatt@shaw.ca> wrote:
If you search back in the archives, there has been lots of discussion in
the past about improving cooling with the fibreglass cowl. You need to open
the bottom exit, and if that is not enough, then open the inlets a bit as
well.
On my new 360 install, I managed to achieve good cooling without having to
change the inlets. But on my previous one, I ended up opening the inlets
before I had good cooling.
Float flying in the mountains in hot weather where you had to do long
climbs was the big problem.
Also, having at least a 2.5 inch prop spacer helps, as then you can pull
the cowl forward enough to allow more air past those front cylinders. In my
previous install, I had only a 1.75 spacer which I think was part of the
problem with the small inlets.
Date: Thursday, October 1, 2009 7:38 am
Subject: Re: [rebel-builders] Float Deck rail tape
To all Elite Builders,
I have just recently finished my Elite 640E and have flown the
first 25
hours. Engine temps are within limits but are to high for my
liking. I am
interested in building the 4 Piece Piper Style Cowling for the Elite.
Are there any plans, instructions, material list, good advise
etc out there.
What else can one do to reduce eng. temps with the regular
"speed cowl" form
MAM?
any help would be appreciated
cheers
Hans
On Wed, Sep 30, 2009 at 2:55 PM, Wayne G. O'Shea
<oifa@irishfield.on.ca>wrote:
I don't follow the "tape" Garry. Nothing I remember being there.
wayne
Sent: Wednesday, September 30, 2009 5:18 PM
Subject: [rebel-builders] Float Deck rail tape
from the
deck.
Hans Kuck
P.O.Box 2212
Sechelt B.C.
V0N 3A0
Canada
Hans Kuck
P.O.Box 2212
Sechelt B.C.
V0N 3A0
Canada
WALTER KLATT
Post by WALTER KLATT » Sun Feb 19, 2012 5:36 pm
Since you already have the 2 inch spacer and the cowl positioned around that, I think you will be forced to open the front inlets as well the bottom exits.
Date: Thursday, October 1, 2009 8:31 am
Subject: Re: [rebel-builders] Re: Cooling with the speed cowl
archives???Ihave a 2" spacer. As you say temps are a problem in
the climb
cheers
Hans
640E
discussion in
need to open
inlets a bit as
well.
without having to
the inlets
do long
you can pull
cylinders. In my
part of the
first 25
liking. I am
the Elite.
etc out there.
"speed cowl" form
MAM?
cheers
Hans
<oifa@irishfield.on.ca>wrote: from the
Hans Kuck
P.O.Box 2212
Sechelt B.C.
V0N 3A0
Canada
Hans Kuck
P.O.Box 2212
Sechelt B.C.
V0N 3A0
Canada
Bob Andrews
Post by Bob Andrews » Sun Feb 19, 2012 5:36 pm
Hans,
I opened the exit area substantially, installed a flanged trailing edge on
the cowl bottom, and installed two louver vents on the cowl bottom. With
2200 amphib, I can now fly in the 100 plus desert temps with oil temps
staying below 245 with cyl temps stabilizing around 340, EGT's around 1320
with a 50-60 diff. Will take some pics this afternoon and post them on the
builder site. Have a bit of painting to do on the parts added, but you'll
get the idea on what I did. The louvers are available at Avery Tools ...
made backing plates, and just riveted them on ... I did open them up a bit.
Consider the temp problem with my speed cowl solved.
Cheers, Bob 612e
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Hans
Kuck
Sent: Thursday, October 01, 2009 8:31 AM
cheers
Hans
640E
open
well.
my
first 25
liking. I am
etc out there.
"speed cowl" form
MAM?
cheers
Hans
wayne
from the
deck.
Hans Kuck
P.O.Box 2212
Sechelt B.C.
V0N 3A0
Canada
Hans Kuck
P.O.Box 2212
Sechelt B.C.
V0N 3A0
Canada
Hans Kuck
Thanks Walter, how much can I open the front and still have some strength
left in the cowling. Do you have any measurements and/or pics?
cheers
Hans
exits.
the climb
cheers
Hans
640E
discussion in
need to open
inlets a bit as
well.
without having to
the inlets
do long
you can pull
cylinders. In my
part of the
the Elite.
Hans Kuck
P.O.Box 2212
Sechelt B.C.
V0N 3A0
Canada
Hans Kuck
P.O.Box 2212
Sechelt B.C.
V0N 3A0
Canada
Hans Kuck
Hi Bob if you send me some pics, that would be a big help.
to hansk3d@gmail.com
cheers
Hans
On Thu, Oct 1, 2009 at 11:08 AM, Bob Andrews <robert@montanasky.us> wrote:
Hans,
Cheers, Bob 612e
Kuck
cheers
Hans
640E
open
well.
my
first 25
liking. I am
etc out there.
"speed cowl" form
MAM?
cheers
Hans
<oifa@irishfield.on.ca>wrote: from the ---- ---- -- --
Hans Kuck
P.O.Box 2212
Sechelt B.C.
V0N 3A0
Canada
Hans Kuck
P.O.Box 2212
Sechelt B.C.
V0N 3A0
Canada
Hans Kuck
P.O.Box 2212
Sechelt B.C.
V0N 3A0
Canada
WALTER KLATT
Hans, I sold the engine and cowl with the bigger inlets. But if you look at the archive files under Elite and then Cowling, there are some excellent pics. If you look at Cowl Mod.jpg, that one is almost identical to what I did with mine. Also read the Desc for that one.
Date: Friday, October 2, 2009 7:46 am
strengthleft in the cowling. Do you have any measurements and/or pics?
cheers
Hans
positioned around
well the bottom
exits.
the climb
cheers
Hans
640E
discussion in need to open inlets a bit as without having to the inlets do long you can pull cylinders. In my part of the
flown the
for my
the Elite.
being there.
seal them
Hans Kuck
P.O.Box 2212
Sechelt B.C.
V0N 3A0
Canada
Hans Kuck
P.O.Box 2212
Sechelt B.C.
V0N 3A0
Canada
Hans Kuck
Walter,thanks I will try thatcheers
Hans
cheers
Hans
positioned around
well the bottom
exits.
flown the
for my
being there.
seal them
Hans Kuck
P.O.Box 2212
Sechelt B.C.
V0N 3A0
Canada
Hans Kuck
P.O.Box 2212
Sechelt B.C.
V0N 3A0
Canada
Hans Kuck
Walter I found your pics, looks good. I may have to extend my bottom cowling
past the firewall which is not the case right now. That could be one of my
problems,?or.
I have had lots of helpful advise , thank you !!
Hans
cheers
Hans
positioned around well the bottom flown the for my being there. seal them ---- ---- ---- ---- ---- ---- ---- ---- ---- ---- -- --
Hans Kuck
P.O.Box 2212
Sechelt B.C.
V0N 3A0
Canada
Hans Kuck
P.O.Box 2212
Sechelt B.C.
V0N 3A0
Canada
Hans Kuck
P.O.Box 2212
Sechelt B.C.
V0N 3A0
Canada
Bob Andrews
Hans,
I uploaded some pictures into the E-Cowl area.
Bob 612e
Kuck
Sent: Friday, October 02, 2009 7:47 AM
cheers
Hans
Hans,
bit.
Cheers, Bob 612e
Kuck
cheers
Hans
640E
open
as
well.
my
first 25
liking. I am
etc out there.
"speed cowl" form
MAM?
cheers
Hans
Hans Kuck
P.O.Box 2212
Sechelt B.C.
V0N 3A0
Canada
Hans Kuck
P.O.Box 2212
Sechelt B.C.
V0N 3A0
Canada
Hans Kuck
P.O.Box 2212
Sechelt B.C.
V0N 3A0
Canada
Hans Kuck
Thank youHans
640E
On Fri, Oct 2, 2009 at 10:59 AM, Bob Andrews <robert@montanasky.us> wrote:
Hans,
Bob 612e
Kuck
cheers
Hans
Hans,
on
1320
you'll
bit.
Cheers, Bob 612e
Hans
Kuck
archives???I
cheers
Hans
640E
in
open
as
well.
inlets
pull
In
my
Hans Kuck
P.O.Box 2212
Sechelt B.C.
V0N 3A0
Canada
Hans Kuck
P.O.Box 2212
Sechelt B.C.
V0N 3A0
Canada
Hans Kuck
P.O.Box 2212
Sechelt B.C.
V0N 3A0
Canada
