before I attached the firewall. I would have saved dozens of hours by being
able to stand up straight and work on the the wiring with good light.
Instead I crawled in and out of the cockpit a hundred times and laid on my
back with the elevator horn digging into my spine. Just cleco it in place
and mount your radios from the front to make sure of clearances then take
it off and have fun.
plumbingHi all,
I brought this up with Charlie cuz I know he's just ahead of me --- well,
maybe a lot ahead of me by now ;) --- but anyway, thought I'd cast a wider
net. I'm wondering how soon to rivet on the firewall. I've got the floor
channels in and the cabin floor all drilled, ready to rivet later, after
posts,and wiring. I've riveted in most everything ahead of the cage (Fus-5,
I'detc), except for the panel, panel to firewall braces and anything related to
motor mounts. I've done nothing wrt controls yet.
My plan has been to hold off riveting the panel to allow easier instrument
installation. And to hold riveting motor mount stuff tilll I have a motor
mount. That all leaves open the pros/cons of riveting the firewall now.
off mylike to do it to make rotating the fuselage easier and just to check it
motorlist. How much will I regret this when it comes time to debur or rivet
Drewmount holes, or to do more panel wiring?
-Ben/ 496R
