[rebel-builders] Moose: Elevator trim (crush tube)...was: Ra
Rick Johnson
[rebel-builders] Moose: Elevator trim (crush tube)...was: Ray Allen Servo
Post by Rick Johnson » Sun Feb 19, 2012 8:29 pm
On the website it is dated July 19, 2004. If you click on it chapter 3 dated 10/08/2006 pops up. It is in section 3.5 "Trim Install" page 18, step 42).
Hope this helps,
Rick
SR277
Subject: [rebel-builders] Moose: Elevator trim (crush tube)...was: Ray Allen Servo
Date: Sun, 23 Aug 2009 18:12:08 -0600
Part # is "Crush Tube" listed as EL--0032 in the manual. I thought it was
per a service bulletin, but none is shown on the website. The issue is that
the trim tab actuator arm is simply a 1/4-28 threaded rod. That rod will
bend under moderate force. Hence, once one has the rod cut to proper length
and tested for successful full up/down trim travel, one is to spread proseal
on the threaded rod then slide the crush tube over it. The crush tube,
therefore, is simply an aluminum sleeve (pipe, per se).
Hope this helps and makes sense,
Ted
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Hans
Kuck
Sent: Saturday, August 22, 2009 10:58 AM
Subject: Re: [rebel-builders] Moose: Ray Allen Servo
TED, could you please mail me a copy of the service bulletin regarding the
Ray Allen Servo. I was not aware that there was such a S.B. to
hansk3d@gmail.com
cheers
Hans
On Fri, Aug 21, 2009 at 7:58 PM, Ted Waltman <tedwaltman@gmail.com> wrote:
Fred,
AFAIK, every Moose owner uses this combination servo/actuator arm. Put
sleeve on as per the service bulletin (get a sleeve at your local hardware
store if you don't have one already).
Ted
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Fred
Messinger (fredm)
Sent: Friday, August 21, 2009 3:45 PM
Subject: Re: [rebel-builders] Firewell caulk
Hi Guys,
I'm currently installing the elevator trim tab servo motor on my moose
quick
build.. The one MAM shipped is manufactured by The Ray Allen Company.
Everything (motor casing, clevis forks) is made out of a hard plastic
material. The push rod itself is a threaded metal rod, though.
My questions: Is anyone else using this set up? If not, which system
are
you using?
I confess, I'm a little concerned about those flimsy little clevis forks
the plastic drive pin....especially in cold weather.
Fred
Hans Kuck
P.O.Box 2212
Sechelt B.C.
V0N 3A0
Canada
Windows Live: Keep your friends up to date with what you do online.
http://windowslive.com/Campaign/SocialN ... ine:082009
