Kyle,
Buy an inexpensive short brake from somewhere such as Harbor Freight (e.g. <
$60 bucks) and get some 0.032". Make your own then you'll have the brake
for other tasks when you're done.
Ted
bscheube@dcsol.com
Sent: Wednesday, January 28, 2009 12:05 AM
Subject: [rebel-builders] RE: TAIL CONE STRINGERS (BEEF-UP)
here are a couple other ideas for tail cone
https://mail.dcsol.com/file/area107/Bottom422.jpg
https://mail.dcsol.com/file/area107/H_StabMount_c.jpg
https://mail.dcsol.com/file/area107/AccessHoles.jpg
https://mail.dcsol.com/file/area107/DoublersLabeled.jpg
bob moose191
On 1/27/2009 2:09 PM, alpsnowman@gmail.com wrote to rebel-builders:
-> MOOSE BUILDERS,
-> FOR THOSE OF YOU WHO BEEFED UP THE TAIL CONE OF YOUR SR3500 USING THE 2"
-> U-CHANNEL MATERIAL, THAT IS INCORPORATED INTO MANY OTHER AREAS OF THE
-> AIRFRAME, AND RAN IT BETWEEN BULKHEADS:
-> I AM TRYING TO FIND THE MOST COST/TIME EFFECTIVE WAY TO MAKE, OR BUY
100'+
-> OF THIS TO INCORPORATE INTO A TAIL CONE BEEF-UP, SIMILAR TO HOW STEVE AND
-> MANY OTHERS DID IT; USING CORNER WRAPS AND ADDITIONAL STRINGERS IN FLOOR
AND
-> ROOF - THAT GO BETWEEN BULKHEADS.
-> MAM WANTS WAY TOO MUCH PER FOOT FOR THEIR U CHANNEL MATERIAL, SO I NEED
TO
-> FIGURE OUT ANOTHER WAY. ANY ADVICE IS APPRECIATED.
-> THANKS
-> KYLE
-> 019SR
-> On Mon, Jan 26, 2009 at 4:59 PM, <bransom@dcsol.com> wrote:
-> > I meant to say that MAM instructions are to drill the two additional
holes.
-> > Mine (496R) doesn't have the holes predrilled either, which just seems
-> > little odd since the rest of the holes are already there. Guess I'll
just
-> > go ahead and drill them for now.
-> > -Ben
-> > > Hi Ben
-> > > Mine don't have those holes. May be it because mine is a later S/N
802R
-> > > Charlie
-> > > ----- Original Message -----
-> > > From: <bransom@dcsol.com>
-> > > To: <rebel-builders@dcsol.com>
-> > > Sent: Monday, January 26, 2009 10:41 AM
-> > > Subject: [rebel-builders] rear spar attach bracket
-> > > > Hi all,
-> > > > MAM has a couple extra holes drilled in the rear spar attach
bracket.
-> > Are
-> > > > these just extra rivet holes or are they for some other purpose?
-> > > > Picture for reference:
-> > > > http://mae.ucdavis.edu/ransom/Murphy/mi ... Attach.jpg
-> > > > Thanks,
-> > > > -Ben, 496R
-> > > > List archives located at: https://mail.dcsol.com/login
-> > > > username "rebel" password "builder"
-> > > > Unsubscribe: rebel-builders-unsubscribe@dcsol.com
-> > > > List administrator: mike.davis@dcsol.com
