Battery(PC 625)/IVO Prop
Charles Dixon
Post by Charles Dixon » Fri Feb 17, 2012 11:27 pm
I found the battery on the net for $89 plus shipping.I am now in the
Gulf of Mexico
and do not have the address w/ me.I also put one on my Aeronca 15AC
Sedan (using a 337).There are a lot of these battiers being used in
Alaska.They really spend the prop around.The only disadvantage is that
they can not be recharged w/ a trickle charge.You need at least a 10amp
if it needs a charge while on the ground.
Has anyone tried the IVO Prop magnum 76" adjustable on the 0-235C1B.My
engine puts out 115hp at 2700 RPM for 5 minutes.I want to find a prop
that will give me this RPM for short field takeoffs(Max time at 2700
will be less than 1 minute).A friend is going to let me try his,but I
have to get the adapter for my engine.I will let YA'LL know how it works
if I ever get off this oil rig.
REBEL112R
Post by REBEL112R » Fri Feb 17, 2012 11:27 pm
I knew a Charles Dixon that worked for Bechtel in Alaska in early 70's, is
this the same person.
Post by Walter Klatt » Fri Feb 17, 2012 11:27 pm
<!doctype html public "-//w3c//dtd html 4.0 transitional//en"> Thanks all for this great information. I have located a few sites on the web if anyone else is interested, both in Canada and the USA. Locally in Vancouver, I have found that I can get them at Polar Battery.
ODYSSEY Drycell tm Batteries for motorcycles, personal watercraft, car and truck
Odyssey Direct
Gulf of Mexico
