TR: [rebel-builders] firewall forward
Jean Poirier
Post by Jean Poirier » Sun Feb 19, 2012 8:02 pm
Hello
I did put my engine on the airplane yesterday, it was a great moment!
Shit! There is a lot of work done but a lot to be done too!!!!
I put de complete C-152 exhaust system that I bought used at the Sun'Fun
couple of years ago. Not to bad! Just for fun, I put the PA-22 style nose
bowl that I have in front of it.... I think I will have to make some
fiberglass work to do to change a bit the angle of the bottom part. It
gone be a bit more "fat" than a speed cowl! We will see...
Before ordering some parts from Spruce, I would like to have your opinion
if everythings is ok or if I should buy something else
Carburator intake assy (carb heat box) #08-01300
S.S. Cabin heat box #08-04025
Oil filter adaptor # 08-00975
ACS Gascolator #10580 and braquet #10371
Should I buy the soleinoid switch from a local auto store?
For the alternator, may be Iwill order braquet kit from Vans and use a
automotive alternator, is a 0-235 case or boss mount?!?
Many of you have use Vans baffles kits... which one (RV6-7-9 0-320 kit)?
Is a 0-320 kit will fit a 0-235 engine?
Thank to all of you
Jean
Rebel 747R
__________ Information NOD32 3614 (20081114) __________
Ce message a ete verifie par NOD32 Antivirus System.
http://www.nod32.com
