Scales: Was:Re: [rebel-builders] list of items for a Moose
Dave Ricker
Post by Dave Ricker » Sun Feb 19, 2012 7:06 pm
LOL! Christmas presents!
OK, if you want to do bathroom scales and have a bit of time to kill & like making gadgets (sounds like a homebuilder!) then you could make up a set of lever arms to reduce the load on the scale and use just one scale per wheel. Probably cost more than buying 7 sets of scales but then there's the educational factor!
W
____________|_________________________
A Lever Arm |
|-------------------------| Bathroom Scale
Basically you want to portion the load so that the scale sees a weight proportional to the wheel weight divided by the lever arm ratio and the rest of the lever setup sees the rest of the load. Above, the pivot at A would see 2/3 the weight of the wheel (W) and the scale would see the rest (1/3W). From Charlie's measurement the 3:1 ratio sounds about right.
Charlie Starr wrote:
Forget about scales. It will be a couple years minimum, before you need them. Usually scales can be found through local builders, an EAA chapter or a FBO. If all else fails, I bought seven bathroom scales at Wal-Mart for about $9 each (3 for each main gear and one for the tail wheel). After weighing again before paint, I found they were within 3 pounds (total) of electronic scales. Gave scales as Christmas presents to my fat friends last year.
Charlie Starr - N96CS
David A. Ricker
Fall River, Nova Scotia
Canada
Post by Drew Dalgleish » Sun Feb 19, 2012 7:06 pm
Good math lesson Dave. Tossing the local A&P some cash to get your plane
weighed is money well spent IMHO. If you buy a few odds and ends there's a
chance you won't get blown off when you need some real advice.
W
A Lever Arm |
last year.
David A. Ricker
Canada
Dave Ricker
Post by Dave Ricker » Sun Feb 19, 2012 7:10 pm
Now that's some good advice Drew, always good to stay on the right side of your
AME/A&P!
Hmmm....looks like my ASCII art didn't survive the trip through the packet
maze......the scale thing is something I picked up on back in my car racing
days although we used grain scales.
W
A Lever Arm |
last year.
David A. Ricker
Canada
David A. Ricker
Canada
