[rebel-builders] Rebel - Rudder Deflection & Tail Wheel
Post by Bob Patterson » Sun Feb 19, 2012 7:05 pm
Hi Mike !
Glad to hear you are getting close !! :-)
Use the compression type springs with the MAM tailwheel,
and leave a little slack in the chains - no more than 1/2" of
sag in the middle. That should allow the tailwheel to swivel
far enough to kick out. Rub a bit of grease on the square pin
about every 3rd or 4th flight - same time as greasing the
tailwheel bearings & pivot post ....
It will get a lot better after a few flights !! :-)
http://www.prosumers.ca
On Sunday 28 October 2007 14:49, indabush@hay.net wrote:
Could be a bigger problem ...........................
I am concerned about the high kick out force required on the tail wheel. I
couldn't get it to break away during taxi. This puts a lot of pressure on
the rudder horn, rudder horn stop bolts, lower rudder pivot bolt and pivot
bracket bolts. It has been suggested than lighter weight springs may
work, but I think there is a bigger problem. The standard rudder travel
is supposed to be +-25 degrees. I have 18.5 deg. to the left and only 17
deg. to the right! (I believe that the rudder and tail spring support /
rudder stops were installed according to the manual.) This means that the
tail wheel does not rotate enough to start riding up on the cam before
full rudder travel is reached. How do I increase rudder travel in a
system that does not have any adjustment devise?
Mike.
_____________________________
Michael Ash, C-FNBO
