[rebel-builders] Dynafocal rubber mounts
Eric Fogelin
Post by Eric Fogelin » Sun Feb 19, 2012 4:05 pm
Hello Walter.
I ordered the 94150-40 engine mounts from Aircraft Spruce. Older Murphy
documents listed these as Lord mounts, but they are Barry Mounts (different,
but apparently a reputable company). They fit fine on my Murphy Dynafocal
mount.
I found it confusing ordering mounts. Some require ordering eight mounts for
a complete set, others require only 4. For part 94150-40 you only need order
4 for a complete set. Perhaps that will make the cost look better. Aircraft
Spruce currently lists these at US$56.50. So you will need to order 4 at a
total of US$226.
Hope that helps.
645E
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Walter
Klatt
Sent: Tuesday, October 23, 2007 2:48 PM
To: Rebel-Builders
Subject: [rebel-builders] Dynafocal rubber mounts
I am going to have to order some rubber mounts for the dynafocal mount. But
if anyone has any extras that they can't use for some reason, let me know,
and I might buy them off you.
Anyway, I know I can buy part no. 94150-40 from Aircraft Spruce. I just want
to confirm from someone here too that these are the right ones. Are there
any other better sources for these, and/or perhaps a better quality mount
that you know of that will work with the Murphy dynafocal mount.
John W
Post by John W » Sun Feb 19, 2012 4:05 pm
Hey Walter
I had an issue with my Elite mounts and tracked down
Paul Snyder at Lord Mounts he is the best source of
info
I have found on mounts. He is a great guy.
e mail paul.snyder@lord.com
or ph 814-868-5424 x 6611
Good luck John W
--- Eric Fogelin <elist@whidbey.com> wrote:
Hello Walter.
mount.
total of US$226.
Hope that helps.
645E
Klatt
To: Rebel-Builders
dynafocal mount.
Do You Yahoo!?
http://mail.yahoo.com
