[Subaru/Ross Aero Drive
Jim Cole
Post by Jim Cole » Sun Feb 19, 2012 6:56 pm
I think someone may have mentioned Crossflow last week - one of my hangar
mates was in Collingwood on Sunday and according to the airport - they have
gone out of business. I don't know anything else.
Jim
Rebel 333
On 10/1/2007 8:26 PM, "ray.mason@dcsol.com" <ray.mason@dcsol.com> wrote:
For those looking at a subie, Maxwell Propulsion
http://www.maxwellpropulsion.com has almost or just finished testing all
the components for their EJ25 FWF. I have seen the PSRU and it does look
good. I believe it is the only one out there that is designed by an
aeronautical engineer.
Ray
On 9/26/2007 2:11 PM, im_planecrazy@yahoo.com wrote to rebel-builders:
-> I purchased a damaged Rebel that has a Formula Power Sub engine that
uses the Ross PRSU. I have not run the engine as I had originally intended
to rebuild the plane. I talked to the gentleman that built this Rebel and he
relayed that he had ZERO problems with the engine or the redrive. It had
303 hours on it when I purchased it from the insurance sale. I am thinkling
of selling it though since I highly doubt I will ever have the time to rebuild
it.
-> Keith R661
-> mdb1225@comcast.net wrote:
-> Ken,
-> EPI makes a strong case for not using a subaru engine.
-> The Vans forum comments run 50/50.
-> What does Murphy Air have to say about this?
-> Mike
-> -------------- Original message --------------
-> From: Ken
-> > In general any significant time in this region destroys the psru and it
-> > can do so in minutes. The forces can multiply to several orders of
-> > magnitude higher than the engine could ever deliver. Think opera
singer
-> > shattering the wine glass. No psru is immune to destruction if operated
-> > in the resonant range. If they are aware of the issue, most folks use a
-> > light prop and idle their psru above typically 1200 to 2000 rpm to
-> > attempt to stay away from the first destructive region. It seems that
-> > some units are OK above above 1000 rpm. A heavy flywheel usually
also
-> > helps. My slightly soft Marcotte (small amount of rubber coupling)
-> > seems happiest if I avoid below about 1700 which is effortless except
-> > during warmup. Ross (google sdsefi) idles his above 2000. Torsional
-> > resonance is the big risk with an uncertified engine/prop. Most of us
-> > just don't have access to torsional testing equipment although some
-> > estimates can be calculated if the effort is put in to measure
-> > components. Sadly the safest thing for most of us is still to use an
-> > engine/psru/prop combination that has been successfully operated by
-> > others for a significant time which probably means the next harmonic
was
-> > avoided. A soft element in the drive will reduce the magnitude of the
-> > forces but mostly they are used to attempt to tune the resonant
-> > frequencies out of the normal operating rpm range. As I indicated
-> > previously there are also assembly issues with the Ross psru that must
-> > be addressed. Scary stuff but aircraft engines don't do much better;
-> > even when pampered (and fed with a highly leaded diet) they still fail,
-> > just for different reasons IMO.
-> > http://www.epi-eng.com/BAS-TorVibInt.htm
-> > http://www.vansairforce.com/community/s ... hp?t=19030
-> > Ken
-> > Drew Dalgleish wrote:
-> > >At 01:28 PM 9/25/2007 +0000, you wrote:
-> > >>I am thinking about buying a used Rebel with a Subaru engine and
a Ross
-> > >drive.
-> > >>I would appreciate anyone's thoughts on the what to watch out for
and any
-> > >personal experiences.
-> > >>The owner discussed a problem related to "sympathetic vibrations"
causing
-> > >chattering in the Ross drive at prop rpm's below 1000. Has anyone
else
-> > >experienced this?
-> > >>Thanks,
-> > >>Mike
-> > >Hi Mike I don't have any experience with ross or subaru ( other than
my
-> > >car ) but 1000 prop RPM is slow enough that unless you're
considering
-> > >putting the plane on floats you could always avoid the harmonic
range.
-> > >Drew
-> List archives located at: https://mail.dcsol.com/login
-> Unsubscribe: rebel-builders-unsubscribe@dcsol.com
-> Be a better Globetrotter. Get better travel answers from someone who
knows.
-> Yahoo! Answers - Check it out.
ray.mason
Post by ray.mason » Sun Feb 19, 2012 6:56 pm
Crossflow is definitely gone. Not many have lasted and all have had some
sort of problems. Eggenfeller has done about the best and Maxwell is just
getting back to shipping product after the NSI fiasco.
Murphy does not support any automotive engines.
Ray
On 10/1/2007 2:48 PM, jcole@rangroup.com wrote to rebel-builders:
-> I think someone may have mentioned Crossflow last week - one of my
hangar
-> mates was in Collingwood on Sunday and according to the airport - they
have
-> gone out of business. I don't know anything else.
-> Jim
-> Rebel 333
-> On 10/1/2007 8:26 PM, "ray.mason@dcsol.com"
-> > For those looking at a subie, Maxwell Propulsion
-> > http://www.maxwellpropulsion.com has almost or just finished testing
all
-> > the components for their EJ25 FWF. I have seen the PSRU and it does
look
-> > good. I believe it is the only one out there that is designed by an
-> > aeronautical engineer.
-> > Ray
-> > On 9/26/2007 2:11 PM, im_planecrazy@yahoo.com wrote to rebel-
builders:
-> > -> I purchased a damaged Rebel that has a Formula Power Sub engine
that
-> > uses the Ross PRSU. I have not run the engine as I had originally
intended
-> > to rebuild the plane. I talked to the gentleman that built this Rebel and
he
-> > relayed that he had ZERO problems with the engine or the redrive. It
had
-> > 303 hours on it when I purchased it from the insurance sale. I am
thinkling
-> > of selling it though since I highly doubt I will ever have the time to
rebuild
-> > it.
-> > -> Keith R661
-> > -> mdb1225@comcast.net wrote:
-> > -> Ken,
-> > -> EPI makes a strong case for not using a subaru engine.
-> > -> The Vans forum comments run 50/50.
-> > -> What does Murphy Air have to say about this?
-> > -> Mike
-> > -> -------------- Original message --------------
-> > -> From: Ken
-> > -> > In general any significant time in this region destroys the psru
and it
-> > -> > can do so in minutes. The forces can multiply to several orders of
-> > -> > magnitude higher than the engine could ever deliver. Think opera
-> > singer
-> > -> > shattering the wine glass. No psru is immune to destruction if
operated
-> > -> > in the resonant range. If they are aware of the issue, most folks
use a
-> > -> > light prop and idle their psru above typically 1200 to 2000 rpm to
-> > -> > attempt to stay away from the first destructive region. It seems
that
-> > -> > some units are OK above above 1000 rpm. A heavy flywheel
usually
-> > also
-> > -> > helps. My slightly soft Marcotte (small amount of rubber coupling)
-> > -> > seems happiest if I avoid below about 1700 which is effortless
except
-> > -> > during warmup. Ross (google sdsefi) idles his above 2000.
Torsional
-> > -> > resonance is the big risk with an uncertified engine/prop. Most of
us
-> > -> > just don't have access to torsional testing equipment although
some
-> > -> > estimates can be calculated if the effort is put in to measure
-> > -> > components. Sadly the safest thing for most of us is still to use an
-> > -> > engine/psru/prop combination that has been successfully
operated by
-> > -> > others for a significant time which probably means the next
harmonic
-> > was
-> > -> > avoided. A soft element in the drive will reduce the magnitude of
-> > -> > forces but mostly they are used to attempt to tune the resonant
-> > -> > frequencies out of the normal operating rpm range. As I indicated
-> > -> > previously there are also assembly issues with the Ross psru that
must
-> > -> > be addressed. Scary stuff but aircraft engines don't do much
better;
-> > -> > even when pampered (and fed with a highly leaded diet) they
still fail,
-> > -> > just for different reasons IMO.
-> > -> > http://www.epi-eng.com/BAS-TorVibInt.htm
-> > -> > http://www.vansairforce.com/community/showthread.php?
t=19030
-> > -> > Ken
-> > -> > Drew Dalgleish wrote:
-> > -> > >At 01:28 PM 9/25/2007 +0000, you wrote:
-> > -> > >>I am thinking about buying a used Rebel with a Subaru
engine and
-> > a Ross
-> > -> > >drive.
-> > -> > >>I would appreciate anyone's thoughts on the what to watch
out for
-> > and any
-> > -> > >personal experiences.
-> > -> > >>The owner discussed a problem related to "sympathetic
vibrations"
-> > causing
-> > -> > >chattering in the Ross drive at prop rpm's below 1000. Has
anyone
-> > else
-> > -> > >experienced this?
-> > -> > >>Thanks,
-> > -> > >>Mike
-> > -> > >Hi Mike I don't have any experience with ross or subaru ( other
than
-> > my
-> > -> > >car ) but 1000 prop RPM is slow enough that unless you're
-> > considering
-> > -> > >putting the plane on floats you could always avoid the harmonic
-> > range.
-> > -> > >Drew
-> > -> > List archives located at: https://mail.dcsol.com/login
-> > -> > username "rebel" password "builder"
-> > -> > Unsubscribe: rebel-builders-unsubscribe@dcsol.com
-> > -> > List administrator: mike.davis@dcsol.com
-> > -> List archives located at: https://mail.dcsol.com/login
-> > -> username "rebel" password "builder"
-> > -> Unsubscribe: rebel-builders-unsubscribe@dcsol.com
-> > -> List administrator: mike.davis@dcsol.com
-> > -> Be a better Globetrotter. Get better travel answers from someone
who
-> > knows.
-> > -> Yahoo! Answers - Check it out.
