[rebel-builders] fus10 vs fus 70
Robert Johnson
Post by Robert Johnson » Sun Feb 19, 2012 2:56 pm
Hi Jean: My Rebel has the same as what your saying but I doubled up with
.016 material behind the rear gear leg (drag brace) and will do same for the
top behind the firewall and use the Fus 70's for the bottom. Bob J
Sent: Tuesday, March 13, 2007 6:37 PM
Subject: [rebel-builders] fus10 vs fus 70
The top rear and bottom are in place, the 2 last one should go in the
firewall area (in top) and the 2 fus-70 at the bottom.
A "blind" builder
Jean
Rebel 747R
Post by Ken » Sun Feb 19, 2012 2:56 pm
I think you are saying that MAM recommends FUS-70 on the bottom of the
firewall and FUS-10 everywhere else. I think you would be fine like
that Jean. I'm happy with mine like that.
jean.poirier@oxyportneuf.com wrote:
How bad is the fus10 installation is still not very clear for me. MAM supply 6x FUS-10 and 2x FUS-70. The 2 fus-70 go between the fire wall
and the cabine frame. Is the "must replace " was for at the origin just for those 2 and than evoluate in "all must be change". Some talk
about fus-452? Is it the same part with .032 instead .020 and .025? It look easier to fit a seconf fus-10 as a doubler thant to work
with .032"...
The top rear and bottom are in place, the 2 last one should go in the firewall area (in top) and the 2 fus-70 at the bottom.
A "blind" builder
Jean
Rebel 747R
