It may be heresy to mention his name here, but Chris Heintz has some good
information on his site.
http://www.zenithair.com/kit-data/ht-87-1.html
Another consideration that I read somewhere.... Often the spacing of the
rivets is based on the need to use more rivets to keep the joint flat than
are necessary to carry the shear load giving an extra margin of strength.
More food for thought.
Allen Poulsen
786R
Sent: Wednesday, September 27, 2006 11:34 AM
Subject: [rebel-builders] Rivet strength
I recently had a short discussion with Darryl Murphy regarding the use of
Avex pull rivets vs solid rivets. In summary, Darryl pointed out that the
shear strength of the skin in most places (e.g. 0.025 thickness I believe
he
was using as an example) is only about 165lbs. Hence, his contention is
that the Avex is plenty strong enough--to go stronger (his point) means
that
the skin fails versus the rivet failing.
Also, there doesn't seem to be any instance (that I'm aware of) where an
Avex rivet installation failed on a Rebel, SR or Moose that caused any
problem (that would otherwise have been prevented thru the use of a solid
rivet).
Food for thought...
Ted
eric.r@dcsol.com
Sent: Wednesday, September 27, 2006 9:25 AM
Subject: Re: [rebel-builders] RE: Dimpled Rivets
O.K., I have a question on the rivet substitution chart. Am I reading
correctly that a dash-3 solid aluminum rivet is far superior in bearing
shear to any avex 1/8 installation?
On 9/26/2006 7:53 PM, mike.davis@dcsol.com wrote to rebel-builders:
-> No problem, I've moved it into General Documentation.
-> Mike
-> From: "Dale Fultz" <dfultz17086@earthlink.net>
-> Sent: Tuesday, September 26, 2006 7:05 PM
-> Subject: Re: [rebel-builders] RE: Dimpled Rivets
-> > Hi Mike,,, Sorry to cause you problems, I guess I got the rivet
-> > chart in the wrong section could you put it in the appropriate
-> > place so everyone can find
-> > it.. I believe it is in the Elite Misc. file section.. Thanks Dale
-> > SR-033
-> > From
List archives located at: https://www.dcsol.com/login username "rebel"
password "builder"
