wake turbulence. You would take every bit of control movement available. It
would be nice not to grate your knuckles across the panel in the process,
but that would probably not be a big concern at that moment.
By the way, while you're inverted and experiencing negative G, use rudder
input opposite that of the stick.
_________________________________________________________________From: bransom@dcsol.com
Subject: Re: [rebel-builders] Changes to panels - Stick Clearance - pedal
travel
Date: Thu, 26 Oct 2006 07:48:26 -0800
Sounds like a good thing in general, assuming not so short as to increaseI shortened the stick such that I could get full forward and full
aileron at the same time without hitting the panel. Not sure I needed to
as I can't imagine actually needing that combination.
required stick forces too much. Don't know about the Rebel, but I've used
simultaneous full forward, full aileron (and nearly full rudder) in a slip.
-Ben
Stay in touch with old friends and meet new ones with Windows Live Spaces
http://clk.atdmt.com/MSN/go/msnnkwsp007 ... &mkt=en-us
