[rebel-builders] Rebel - Covering Flapperons
Post by Bob Patterson » Sun Feb 19, 2012 2:16 pm
Hi Jim !
The only thing most folks miss is putting the layer of 1/4"
thick, or so, polyester batting over the leading edge of the flapperons.
It will be glued lightly in place, covering all of the sheet aluminum
leading edge. The fabric is stretched over the batting - it covers the
rivet heads and gives a nice smooth surface to the leading edge.
When the fabric shrinks, the batting will be compressed so it's
hardly noticeable, but it protects the rivet heads and allows for
smooth movement under the top wing skin. You can add Teflon tape
after final coats, for a tight, smooth seal.
If you just apply the fabric to the bare aluminum, you will get
pinholes in the finish. When the Polyfiber finishing coats dry, they
give off solvents. If you don't have the batting there so the gases
can escape easily, they bubble up through the fabric & leave pinholes !
You can buy rolls of 6 ft. wide polyester batting at most fabric
stores - it's not expensive.
On Monday 16 October 2006 12:11 pm, pequeajim@dcsol.com wrote:
I did a search for some feedback on covering the Rebel flapperons and
happily
found some references to a step or two that is not detailed in the murphy
instructions. My question is that, although quite proficient at covering
large
model wings, some of the terms relating to the full scale covering are new
me.
Has anyone on here detailed step by step the covering process? I'm not
worried about getting it done, just about forgetting something that I should
have done that was not explained in the build manual.
pequeajim
Post by pequeajim » Sun Feb 19, 2012 2:16 pm
Is that the only area that you put the batting down, the leading edge?
On 10/17/2006 11:42 AM, beep@sympatico.ca wrote to rebel-builders:
-> Hi Jim !
-> The only thing most folks miss is putting the layer of 1/4"
-> thick, or so, polyester batting over the leading edge of the flapperons.
-> It will be glued lightly in place, covering all of the sheet aluminum
-> leading edge. The fabric is stretched over the batting - it covers the
-> rivet heads and gives a nice smooth surface to the leading edge.
-> When the fabric shrinks, the batting will be compressed so it's
-> hardly noticeable, but it protects the rivet heads and allows for
-> smooth movement under the top wing skin. You can add Teflon tape
-> after final coats, for a tight, smooth seal.
-> If you just apply the fabric to the bare aluminum, you will get
-> pinholes in the finish. When the Polyfiber finishing coats dry, they
-> give off solvents. If you don't have the batting there so the gases
-> can escape easily, they bubble up through the fabric & leave pinholes !
-> You can buy rolls of 6 ft. wide polyester batting at most fabric
-> stores - it's not expensive.
-> ......bobp
-> http://bpatterson.qhealthbeauty.com
-> http://apatterson2.qhealthzone.com
-> http://apatterson2.qbeautyzone.com
-> -------------------------------orig.-------------------------
-> On Monday 16 October 2006 12:11 pm, pequeajim@dcsol.com wrote:
-> > I did a search for some feedback on covering the Rebel flapperons and
-> happily
-> > found some references to a step or two that is not detailed in the
murphy
-> > instructions. My question is that, although quite proficient at covering
-> large
-> > model wings, some of the terms relating to the full scale covering are
new
-> to
-> > me.
-> > Has anyone on here detailed step by step the covering process? I'm not
-> > worried about getting it done, just about forgetting something that I
should
-> > have done that was not explained in the build manual.
Yes ! It covers ALL of the sheet aluminum at the front
of the ailerons, wrapping from bottom to top rear edge.
-> Hi Jim !
-> ......bobp
-> happily
murphy
covering
-> large
new
-> to
-> > me.
should
pequeajim
One more thing Bob. The 1/4" batting, is this the 4oz. stuff? In looking
around on the web, it seems to come in 4, 6, and 8 oz. thickness?
-> > -> The only thing most folks miss is putting the layer of 1/4"
-> > -> thick, or so, polyester batting over the leading edge of the
