[rebel-builders] Painting a ploished aircraft
Post by Drew Dalgleish » Sun Feb 19, 2012 2:03 pm
I can tell you the wrong way is to polish it first. I have some spots on
mine with poor paint adhesion (read big flakes missing) either from not
prepping the bare metal well enough or from silicon contamination. If I was
doing it again I'd rubbing compound first then paint then polish. The metal
needs to be perfectly clean and roughed with a scotchbrite before priming.
At 05:46 PM 8/4/2006 -0800, you wrote:
I really like the shiny look of a polished aircraft with accent paint.
Kind of like
a two tone paint job where one tone is paint and the other is the polished
aluminum.
The question that I have is that in reading up on the subject, I wonder when
you paint it? Before you polish, or after? If I polist first, then the
surface
becomes more slippery and the paint does not adhear as well?
Is this true? How is it normally done, in what sequence?
