though. I have received responses from two other builders who are both
flying and they have similar slop and report no in flight problems other
than a little control harmony issue and a bit of wandering on heading when
letting go long enough to glance at charts or tune radios. To me, this is
great news. I had considered this problem to be the worst of the obstacles
I am facing but now I am simply moving on to my other troubles.
I did a differential compression test on two cylinders today. One on each
side of my V8. 62/75 on one side and 65/75 on the other. (75 instead of 80
because my automotive tool has a chart for percentage leakage based on 75)
That's not good. I didn't even bother checking other cylinders at that
point. Low compression along with the oil that collects on the head bolts
when running the engines, I now believe, not that my head gaskets are blown,
but rather my head gaskets are not the right ones. I'm going to make some
phone calls, make sure I use the correct gaskets, and install new ones
tomorrow. I'm hoping that my cooling problems will either go away or
improve significantly once that's done.
044SR
Betti
Sent: Wednesday, August 02, 2006 4:32 PM
Subject: Re: [rebel-builders] Anyone wanna buy an almost finished Super
Rebel?
I remember my Elite being that way after I rigged them. I mentioned it to
Robin at MAM and he didn't think it was an issue. Do you have the lever
assembly riveted in on the ends of the control tubes at the root of the
fuselage? I think there is some flex there since I only have a couple clecos
there, I since pulled 2 small rivets in them temporarly and that seem to
help some. I haven't looked at it that close in a several months but I think
I have the same result you have in my shop.
Mike Betti
771 E
Sent: Wednesday, August 02, 2006 2:08 PME
Subject: RE: [rebel-builders] Anyone wanna buy an almost finished Super
Rebel?
Yes, I could see the mixer plate play. So I jammed a screwdriver in there
and eliminated the mixer plate play completely. That didn't help any
noticeable amount. Can you give me an idea of the magnitude of the play
you
have? I tied down the stick, then moved the aileron while holding a ruler
up to the trailing edge to determine that mine has an inch of play. Does
yours "bounce" when you move the stick then stop moving?
Charlie Starr
Sent: Wednesday, August 02, 2006 9:20 AM
Rebel?
Mike,
My ailerons also have a bit of freeplay (N96CS a SR). Most seems to come
from the pulley on the cabin side of the wing root (a sort of twisting
movement), also the "bat shaped" mixer plate on the cabin roof allows some
movement of the push rods. I have tightened everything and eliminated
most
of the slop, but there is still some. Just returned from a 16 hour trip
from the FL Gulf coast to OSH and though fairly stable (even in IFR
conditions), I wish I could make the ailerons tighter and more effective.
Charlie Starr (SR N96CS).
To: "Rebel Builder's List" <rebel-builders@dcsol.com>
Sent: Tuesday, August 01, 2006 10:47 PM
Subject: [rebel-builders] Anyone wanna buy an almost finished Super Rebel?
I can't believe I have another major problem! I hooked up the left
aileron
with the wing to fuselage push-pull rod and when moving the stick I
noticed
the aileron bouncing a bit when I stopped moving the stick. I tied the
stick down and with it held in place I can move the aileron a full inch
at
the trailing edge! I tried to narrow down where the worst of it is being
caused which I really need a second person to help do. Aileron to the
wing
root end of the torque rod seems solid as a rock. The worst of it seems
be the push-pull rod I just hooked up but again it's hard to be sure
without
a second person to hold things. The frustrating thing is I reviewed the
entire system against the manual and I have built it exactly as described
in
the manual. Every builder should have run into the same problem. There
should be a "to avoid excessive free play the builder should take care
to..." entry in the manual. HELLLLLPPPPP!
Went out to the hangar today and after weeks of no sign of leaks from the
tanks the left wing tank is leaking now!
What next?
044SR
Checked by AVG Free Edition.
Version: 7.1.394 / Virus Database: 268.10.5/405 - Release Date: 8/1/2006
