Moose: update on tail wrap oil can & magneto rotor groov
Ted Waltman
Moose: update on tail wrap oil can & magneto rotor groove
Post by Ted Waltman » Sun Feb 19, 2012 1:47 pm
I updated pictures of the oil canning problem with FUS-413 and my simple "L"
brace fix to <http://www.i1ci.com/flying/Moose/FusWrap/FusOilCan.html>
http://www.i1ci.com/flying/Moose/FusWrap/FusOilCan.html. I also uploaded
two pictures to the Area 107 - S/M Fuselage section.
I also uploaded a picture of a nasty groove worn in my right mag rotor due
to a contact screw (the unused one on the R-mag) working its way loose and
falling into the rotor:
<http://www.i1ci.com/Flying/Moose/Magnet ... orCap.html>
http://www.i1ci.com/Flying/Moose/Magnet ... orCap.html. A picture of
this is also in Area 111- S/M Engines.
Recommend you take out that unused contact screw on your R mag distributor
at the earliest possible time!
Ted Waltman
Moose 142SR
