[rebel-builders] rebel wing inspection holes
Post by Wayne G. O'Shea » Sun Feb 19, 2012 1:47 pm
As far as I'm concerned they all serve no purpose if you use one lug anchor
nuts for the back side!
;O)
Sent: Friday, May 12, 2006 12:58 PM
Subject: [rebel-builders] rebel wing inspection holes
Hi all,
Question on the aileron hinge inspection holes on the left wing. (10.10
step 49). Seems the hole near the tip serves no purpose. Just pull the tip
like the right side.
The one inboard of rib number 7 is more problematic. As I read the manual
it ends up exactly where the slot is for the control horn. Can't see how
this is supposed to work. Any help?
Allen Poulsen
786R
apoulsen
Post by apoulsen » Sun Feb 19, 2012 1:47 pm
Wayne,
On planes you've seen with the holes, where did they put the one by the slot
for the control horn?
All I've found for nutplates have two lugs. Is there any problem grinding
one side off to fit?
Allen
Sent: Friday, May 12, 2006 1:02 PM
Subject: Re: [rebel-builders] rebel wing inspection holes
anchor
;O)
Hi all,
Allen Poulsen
786R
I have not seen a Rebel with trailing edge holes in the bottom skin!
On the one lugs I only use a single rivet anyhow...BUT it has to go in the
outer hole of the horn so that the rivet clears the aileron bracket and it's
shim if needed. Guess you could use a solid C/Sunk rivet to attach if using
a shorter lug on a normal anchor nut. Just be sure you are not using one of
those cheap formed anchors...like the floating F5000-3's. The ones I was
distributing had a GENEROUS thread depth and where made from solid stainless
so they had better threads than an standard AN nut. Don't leave yourself
short and at least use a high quality FIXED anchor nut.
Sent: Friday, May 12, 2006 4:39 PM
Wayne,
slot
Allen
anchor
;O)
Hi all,
tip
manual
Allen Poulsen
786R
apoulsen
Know where to find them now?
Allen
Sent: Friday, May 12, 2006 5:19 PM
it's
using
stainless
Wayne,
slot
Allen
anchor
;O)
tip
manual
how
Haven't looked anywhere....what I had available were NOS stock.... circa
Norseman factory or when Canadair was turning C47's into DC-3's!
I have 90 some thousand anchor nuts on my shelves...but none I am willing to
state my reputation and your safety on... to use to mount
flaperons/ailerons. The one box I had was the only ones I felt VERY
comfortable with...unfortunately the lads before you have cleaned me out.
Sent: Friday, May 12, 2006 5:38 PM
Allen
it's
using
stainless
Wayne,
slot
grinding
Allen
tip
manual
apoulsen
Thanks anyway. I'll keep looking
Sent: Friday, May 12, 2006 5:46 PM
Allen
it's
using
one
was
stainless
yourself
slot
grinding
tip manual
Jesse Jenks
Post by Jesse Jenks » Sun Feb 19, 2012 1:47 pm
I got mine from Wayne (thanks Wayne), but ACS has some that look similar but
with nylon insert like regular nuts. part ms21080.
BTW I used two CS avex rivets in each. Seems to work well.
Date: Fri, 12 May 2006 18:33:16 -0400
willing
out.
Allen
in
grinding
lug
see
apoulsen
Jesse,
Thanks, I kept looking for them under "nutplates" without sucess.
Allen
Sent: Friday, May 12, 2006 11:38 PM
but
bransom
Post by bransom » Sun Feb 19, 2012 1:47 pm
Allen
You can get these at vansaircraft.com or ACS. Search either place
for "anchor" or "anchor nut" (no quotes).
Note, altho these are not nylock, the AN3 threaded hole is a bit pinched such
that they are locking. Perhaps after several uses some locktite will be
needed. dunno.
I've also got some pictures on my home comptuer how I did my inspection
hole/cover plate on rib #7 -- happy to post if you'd like. Basically the doubler
picks up the flaperon horn slot as well as the cover plate hole. I put the
inspection holes in partly because I hadn't known of Wayne's recommendation
at first, but then too, IMO it ain't bad to be able to peek inside at annual.
-Ben
Jesse,
Allen
similar
but
apoulsen
Ben,
I'd love to see the pictures. They always help. You mention doublers. I've
seen one Rebel with a doubler in this area but I thought it was a repair.
Can't remember seeing anything in the manual. Unfortunately don't remember
how they did the inspection holes.
Allen
Sent: Tuesday, May 16, 2006 3:22 PM
Allen
such
needed. dunno.
doubler
recommendation
annual.
-Ben
Jesse,
Allen
similar
but
