believe you can also upgrade the older ones to do the same.
Other problem I find with the VAL is sooner or later that little flip-flop
toggle switch causes you fits...doesn't it Garry!
Sent: Tuesday, March 28, 2006 9:01 PM
Subject: Re: [rebel-builders] Rebel Transponder
theFWIW - I have dual VALCOM VHF in my SR and have had excellent results. My
only complaint with them is that when power is removed they do not hold
andlast freq. but revert to 121.9 and 121.7 on the flip flops. No problem to
again select the desired freq. when re-powering for next flight. Size is
about the same as ICOM and price is much less.
Charlie Starr
Sent: Tuesday, March 28, 2006 11:15 AM
Hi Jim !
I've had good luck with the VAL-COM units. They're about the same
size as the Icoms, but have a better display - lighted tubes that dim
automatically at night. Same flip-flop channel setup, but with flip
switch rather than push switch. Big attraction was price - $650 or
less .... and fabricated wiring harness for an extra $75.
On Tuesday 28 March 2006 11:10 am, pequeajim@dcsol.com wrote:That was one that I was looking at, thanks. It is reasonably priced
andreadily available.
On 3/28/2006 4:22 AM, jean.poirier@oxyportneuf.com wrote to
rebel-builders:
-> Hello Jim
-> As for the com, 3 years ago I have bought a Icom IAC200 flip/flop
digital -> for a PA22 I had. One of my best purchase, price, size
whattransmission -> were top notch!
-> Jean
-> Rebel 747R
-> From: <pequeajim@dcsol.com>
-> Sent: Monday, March 27, 2006 10:16 PM
-> Subject: [rebel-builders] Rebel Transponder
-> > I'm looking for a small com/transponder setup and am wondering
supportedby-> > suggestions you guys have? I have a Terra, but they were aquiredsellFree
-> > Flight and do not support my models any more. I though I wouldthem
-> > on
-> > ebay since they work and then get something that will be
if it -> > breaks in the future.
-> > A very small digital would be great.
-> > Jim!
