[rebel-builders] RE: plastic coating, Goof-off
Post by Drew Dalgleish » Sun Feb 19, 2012 10:31 am
Hi Ben I haven't tried it but maybe a heat gun would soften it enough to
peel off properly
At 10:24 AM 3/20/2006 -0900, you wrote:
OK, with no other suggestions, I'm going to answer my own question here.
This is also a two-fold answer. 1.) More beer is about it, as I suggested
when posing in the first place. 2.) more beer? ...no, actually, I found
that
using scotch brite only makes things messier. It is better to just use more
solvent, an aluminum scraper and often a second soaking, then wrags. Still
takes a lot of patience.
I guess this may not be a real common problem out there, especially with new
kits, but my kit had something special in how it was baked in a Texas barn
for
7 years before I got it (now 10 years total). It is tempting to suggest
that
new kit owners consider peeling off protective plastic from inside pieces
(ribs
and bulkheads), making sure to re-label accurately, to avoid this kind of
headache if the kit sits several years before getting to these parts of
construction.
-Ben
On 3/17/2006 2:35 PM, bransom wrote to rebel-builders:
This is something I thought I knew enf about -- getting the aged and
brittle
plastic protective coating off of aluminum -- but lately it is really
cutting
into
my sense of fun. I've taken care of this problem reasonably well when
parts
fit into a covered aluminum roasting pan (about 12x20") with Goof-off, or
with
flat pieces that I could cover with aluminum foil. But now I'm doing the
fuselage bulkhead pieces and they are big or awkward for the above,
especially where the plastic has come off but the sticky layer remains. I
resort to working this with green scotch brite and more Goofoff and then a
rag, but it is very tedious, messy, time consuming. Anyone know of any
tricks here or should I just add more beer and quit whining?
thanks,
-Ben
bransom
Post by bransom » Sun Feb 19, 2012 10:31 am
Hi Drew, thanks for the suggestion, but nope, I had tried that and no effect
at all. Sorta surprising.
-Ben
peel off properly
here.
that
Still
new
for
that
(ribs
construction.
-Ben
brittle
cutting
into
parts
or
with
then a
thanks,
-Ben
Post by Bob Patterson » Sun Feb 19, 2012 10:34 am
Hi Ben !
Geeeee !! If it's THAT hard to remove, <I>'d be tempted just to
leave it on - sounds like great protection !! ;-) You could just
strip it off at the joints, so you could epoxy them, and leave the
plastic on the big areas .... doesn't sound like it'd EVER come
off !!! :-) More time for beer ! :-)
effect at all. Sorta surprising.
-Ben
to peel off properly
here.
suggested when posing in the first place. 2.) more beer? ...no,
actually, I found
that
use more solvent, an aluminum scraper and often a second soaking,
then wrags.
Still
with
new
barn
for
suggest
that
pieces
(ribs
of headache if the kit sits several years before getting to these
parts of construction.
-Ben
On 3/17/2006 2:35 PM, bransom wrote to rebel-builders: brittle
cutting
into
parts
or
with
then a
bransom
Post by bransom » Sun Feb 19, 2012 10:34 am
Believe me, that crossed my mind. Especially if I were going to prime inside,
this would seem really crazy to be spending all this time and fun with solvents
only to put something else back on! But nah, that ain't right. Also, the stuff
really does have a time factor to it -- some of it is peeled and brittle (flakes
off easily) right next to other parts stuck for another 10 years. Hmmm,
maybe if I just fly with the doors off all those millions of little white plastic
fragments would eventually blow out!
But now I'm obsessed and winning -- must be the fumes. :)
-Ben
Hi Ben !
-Ben
here.
that
Still
new
for
that
(ribs
cutting
or
then a
Hey Ben !! That might be a solution !!!! If the stuff does deteriorate,
maybe it's UV sensitive - might shining a UV or IR light on it overnight
make it crumble & flake off ????????
Might be worth a try ..... ???
inside, this would seem really crazy to be spending all this time and fun
with solvents only to put something else back on! But nah, that ain't
right. Also, the stuff really does have a time factor to it -- some of
it is peeled and brittle (flakes off easily) right next to other parts
stuck for another 10 years. Hmmm, maybe if I just fly with the doors off
all those millions of little white plastic fragments would eventually
blow out!
-Ben
Hi Ben !
no effect at all. Sorta surprising.
-Ben
here.
Still
new
or
then a
bransom
Hi Bob,
Although it is probably UV and air, I did try leaving some parts outside last
summer for a couple weeks and there was no perceptible change. It would
take more time than I can safely leave the parts out. At least I'm not
plagued with all parts having this problem, and notably, the large skins still
peel fine. Problems are mostly with the white plastic coating and not the
clear. Don't understand that.
-Ben
On 3/20/2006 6:18 PM, beep@sympatico.ca wrote to rebel-builders:
blow out!
-Ben
Hi Ben !
question
aged
know
