I am working on the upper corner wraps. Where the upper fus 10 (I am using
fus 70s) joins the fus 33 at bulkhead "B" it won't lay down around the
radius because of the taper. The manual shows something involving a plywood
cutout, but I wasn't sure what they are getting at. Do I need to do some
kind of forming of the radius edge of the fus 70 to make it fit properly,
and if so what is the best way to do it? I am tempted to just ignore it,
because the gap is only visible from inside, but I'm not sure what will
hapen when I rivet it down.
Thanks.
