[rebel-builders] Alternator
Post by Drew Dalgleish » Sun Feb 19, 2012 10:31 am
hi Mike the nipple is for hooking up cooling air from the high pressure
side of your baffles. Whether you need it or not depends on how hot it is
under your particular cowl. I've had good luck so far with my nipondenso
alternator that has no aditional cooling.
At 09:32 PM 3/13/2006 -0600, you wrote:
Hi all,
My 0360 engine core has a Prestolite alternator with a black cover on the
back for maybe hooking a hose to. The nipple end is broke off and I need to
repair. Is this cover necessary and if so, where does it connect to?
Mike Betti
771E
mbetti
Post by mbetti » Sun Feb 19, 2012 10:31 am
OK thanks for the help.
Hi all,
Mike Betti
771E
