Rebel Rudder
Jesse Jenks
Rebel Rudder
Post by Jesse Jenks » Sat Feb 18, 2012 2:07 pm
Brian,
A counter bore is just part of the hole that is a bigger diameter than the
rest. It could be used to get a bolt head or nut to be recessed or flush
with the surface. It is to a bolt what a countersink is to a screw or rivet.
In this case I counter bored for the shop head of the rivet, inside the end
plug.
When you build the elevators just move the offending rivet locations
outboard enough that there is no interference.
Subject: Re: Rebel Rudder
Date: Mon, 31 Oct 2005 20:59:58 -0800
Hi Jesse,
Thanks for the feedback.
Im new to this building game so that will explain my curiosity about a
"counter bore." If you wouldnt mind Jesse could you provide a little more
explanation on the concept as a means of keeping me out of trouble when
building the elevators/fin.
Many thanks
Brian
Sent: Tuesday, November 01, 2005 9:33 AM
Subject: RE: Rebel Rudder
Brian,
I ran into the same problem, and was equally as pi$$ed off about the
manual.
It is the first bit of education you receive that the manual is a piece
junk. You will learn that pretty quick.
I hadn't pulled any rivets before I realized the interference problem.
What
I did was to counter bore slightly the inside of the holes for the 2
offending rivets that go through horn and end plug, and used the shorter
SS
rivets in those 2 locations. When pulled, the shop head is almost flush
the inner surface of the plug and the opposing rivets from the side will
clear them. As I remember, this problem is caused by the the hole
location
of the two side rivets that are located by the rudder (or elevator)
skin.
With the remaining radialy spaced rivets you can locate them far enough
away
from the end of the plug that there is no clearance problem. On the rest
the control surfaces I changed those hole locations slightly. If you
counter
bore the inside of those 2 holes, use a drill press and secure the end
plug
well. The drill bit will grab and want to go all the way through. If you
have an actual counter bore bit, even better.
Subject: Rebel Rudder
Date: Sun, 30 Oct 2005 23:08:55 -0800
So, I very very carefully read through the section of the manual on the
Rebel tail feathers as that is where the build was to start.
Then, I very very carefully measured and drilled the rudder parts as
per
the manual and took great care to get the parts all lined up and
fitting
right.
So far so good
Next came the rudder assembly as per the manual. Thus, the rudder
horn
was neatly and properly riveted to the spar cap in a way that would
make
the workmanship of those who built the steel riveted side plates of the
Titanic look like the work of infants building a Meccano set--you know
where this is going right?
Again all went well.
Next came my attempt to rivet the horn and spar cap assembly to the
rudder
spar.
Thats when I discovered that a couple of the rivets used to attach the
cap to the spar could not be inserted in place, and pulled, because of
interference from a couple of rivets used to attach the horn to the cap
about which the manual offered no caution; indeed it was as silent as a
tomb on the subject.
Thats when I nearly had a ##!!0&%##@/!!!!!! bird
Has this happened to anyone else? if it has I would sure appreciate any
fix
that was dreamed up. But somehow I just know in my bones that it's into
hip pocket and out with the wallet to buy a new spar and cap to redo
whole 30 hour effort.
Right?
I thought so!
Sympathy, and expressions of shock grief and horror, may be sent to the
undersigned.
Brian Breathnach
779R
Brian Breathnach
Rebel Rudder
Post by Brian Breathnach » Sat Feb 18, 2012 2:07 pm
Excellent Jessie,
Thanx again
Brian
Sent: Wednesday, November 02, 2005 10:07 AM
Brian,
rivet.
end
plug.
Hi Jesse,
Many thanks
Brian
Brian,
manual.
piece
What
shorter
SS
flush
will
location
skin.
enough
away
rest
counter
plug
you
per
fitting
horn
make
know
rudder
cap
any
fix
into
Rebel Rudder
Post by Wayne G. O'Shea » Sat Feb 18, 2012 2:07 pm
Yes and Yes...50% of the time on the stainless RR5606's you'll hear the
mandrel "ping" inside the tube as the stem breaks when pulling. Be sure to
shake the tube around and dump them out thru the 1/4" tapped hole before
final assembly. Also be sure you are dipping these stainless (all the rivets
for that matter) in epoxy before pulling. This will help lock the mandrels
in that don't fly out when pulling.
The trick with the plastic mallet is to hit it hard enough to get the mfg'd
rivet head down tight as you slowly pull up the shop head. Takes some good
timing..but very "doable".
Sent: Tuesday, November 01, 2005 1:02 PM
Hi Wayne,
Thanx for the info.
Im new to building so that explains this question. Does "ping" mean that
mandrel removes itself from the rivet leaving a hole right tru the body of
the rivet? Also if you could elaborate on the use of the "plastic mallet
on
the air riveter head..." that would be great. Is the idea to actually
whack
the riveter head during the process of pulling the rivet?
Thank you
Brian
Sent: Tuesday, November 01, 2005 8:39 PM
Most of the mandrels "ping" right out of the stainless rivets when the
mandrel breaks anyhow.
Another trick is the old plastic mallet on the air riveter head as you
slowly pull the rivet...to drive the rivet into place as the shop head
forms.
Sent: Monday, October 31, 2005 11:29 PM
Hi Mike,
Thank you for the prompt response.
Have established that the absence of a mandril in a rivet does not
affect
the safety of the kit so the intent is to remove the mandril and that
will
allow me to insert and pull the appropriate rivets. Being new to the
build
experience I was/am intrigued by the low air pressure and hard push
technique you describe below. Will keep that in mind for sure.
thanx again Mike
Brian
From: "Jones, Michael" <Michael.Jones@snclavalin.com>
Sent: Tuesday, November 01, 2005 4:31 AM
others
push
really
give
it
per
the right.
horn
was
Titanic
this
is
rudder
cap
as
tomb
any
fix
into
Brian Breathnach
Rebel Rudder
Got it!
Thanx
Brian
Sent: Wednesday, November 02, 2005 2:19 PM
rivets
mfg'd
Hi Wayne,
Thanx for the info.
on
whack
Thank you
Brian
forms.
affect
that
will
build
push
give
it
Of
on
as
per
fitting
horn
make
where
this
rudder
because
cap
as
appreciate
any
into
redo
