about 1700lbs, and climb out at this weight is about 600 to 700 fpm at
1000ASL on a 25*C day. This is behind a "slow" cowled (as apposed to "speed"
cowled) Lycoming O-320-C2A x 150HP 3 blade 70" Warp Drive Propellor and
after a 7 to 9 second run to leave the water into a minute breeze.
Sent: Sunday, August 14, 2005 4:26 PM
Subject: Murphy floats
atI wonder if some of you that have an O-320 on floats (straight or amphib)
could share your indicated airspeeds, rate of climb, and at what RPM's. I
would like to compare with my Subaru.
At gross weight warm day (25C) I am getting around 600-700 FPM climb at
75mph indicated (5200 rpm Prop 2363 rpm approx). I am getting 80-85 mph
4500 RPM (Prop 2050). I am on straight Murphy 1800 floats.
Thank you,
Del Schmucker
Information Systems Manager
Keewatin-Patricia District School Board
