Couple of pics posted to "403 - Fly In Photos" [didn't know what
category to post them into]
Older gentleman decided he would not tie the tail of his plane down
before hand-propping it. Forgot he left the throttle half open. Props
it. Starts [of course]. Luckily prop misses him as the plane roars
off. Guy tries to stop it; gets run over by the tail. Wing hits major
steel beam on corner while prop chews through the hangar door.
Can't see it in the pic, but fuselage where wing joins is bent. Hence,
plane is pretty much totaled.
Good lesson for all of us.
Ted
Other: [Someone else's plane] meets hangar; hangar wins
Jim Cole
Thanks for the reminder Ted - I hand prop my Aeronca Chief all the time.
It looks like a Chief but it looks like he has lights in the wing which
of course means electrics. Where is the plane and what kind is it?
Jim
Jim
Ted
Hi Jim !
Looks like a PA-11 Cub, or maybe an early PA-18 Super Cub ....
One good trick when hand swinging is to always turn the fuel OFF
after priming & pulling through, before turning the mags on - that way,
even if it gets away, it won't go more than a minute or so ! ;-)
Jim
Ted
Ted Waltman
I think someone told me it's a PA-12. I'll look closer later this
afternoon and post an update on the list tonight.
Ted
Sent: Wednesday, June 15, 2005 10:50 AM
Subject: Re: Other: [Someone else's plane] meets hangar; hangar wins
Hi Jim !
OFF after priming & pulling through, before turning the mags on - that
way,
Ted
Hi Jim !
way,
whichThanks for the reminder Ted - I hand prop my Aeronca Chief all the
time.
Jim
Props it. Starts [of course]. Luckily prop misses him as the plane
roars off. Guy tries to stop it; gets run over by the tail. Wing
hits major steel beam on corner while prop chews through the hangar
door.
Hence, plane is pretty much totaled.
Ted
"rebel" password "builder" Subscription services located at:
