Plastic Float Access Cover Fix
WALTER KLATT
Post by WALTER KLATT » Sat Feb 18, 2012 10:27 am
Yes, the main problem with MAM's is that the aluminum deck flexes, and the plastic female outer inserts then crack, not the cap itself. That's what these SS retainer rings prevent, and they do work as I have used them now for a whole season. I was even able to continue using some of my existing plastic covers that had started to crack, and it holds them together, too, no problem.
Anyway, it's up to you guys, and whoever wants them let me know now, as this will probably be the last chance to get these ones.
Date: Monday, April 25, 2005 7:34 am
Subject: Re: Plastic Float Access Cover Fix
These might be lighter and have no corrosion issues (stainless
ring) for
a new installation.
Which I guess begs the question whether anyone has tried them or
at
least had a good look?
The ones from MAM are also probably satisfactory on a solid deck
that
doesn't flex.
Schmucker, Del wrote:
I have found that the Beckson DP50 should work. Per the specs they
should fit within the existing holes.
Here is a link:
http://www.beckson.com/twistdp.html
I have found a supplier here in Canada that is to supply them for
around>$10 each. Beckson has assured me that they will support
weight (people
stepping on them) and not break.
Thank you,
Post by Wayne G. O'Shea » Sat Feb 18, 2012 10:27 am
I still say the best solution to the black plastic covers is to remove them
and throw them away!! Replace with .040 round alum covers and 6 screws into
tinnerman nuts. Weather strip foam around the underside keeps the rain water
out of the floats. Install pump out cups/hoses and there is no need to get
in there anyhow.... unless you're doing your fall "mop out" and in that case
a cordless screwdriver makes quick work of popping all the covers off to do
so.
Sent: Monday, April 25, 2005 10:34 AM
These might be lighter and have no corrosion issues (stainless ring) for
a new installation.
Which I guess begs the question whether anyone has tried them or at
The ones from MAM are also probably satisfactory on a solid deck that
doesn't flex.
Here is a link:
I have found a supplier here in Canada that is to supply them for around
$10 each. Beckson has assured me that they will support weight (people
Thank you,
Legeorgen
Post by Legeorgen » Sat Feb 18, 2012 10:27 am
Walter,
I would like 4 of the cover fix's.
Bruce
Garry Wright
Post by Garry Wright » Sat Feb 18, 2012 10:27 am
I agree with Wayne. He did FOKM as described and the metal version is
absolutely trouble free, and probably the lightest choice of any
possibility. I have had them on and off swapping the floats back and
forth and they are easy to use and close to indestructible.
so.
a new installation.
doesn't flex.
Here is a link:
Thank you,
