Walter's trip to Ontario
Post by Wayne G. O'Shea » Sat Feb 18, 2012 1:23 pm
Sure..don't visit me.. see if I care ! LOL
Gonna take over Ontario are they ? :O)
Sent: Tuesday, April 05, 2005 10:25 AM
Subject: RE: Rebel floor
Any Rebels in the Guelph or Brampton areas? I will be out that
way this Friday, but not sure how much time I will have.
Sent: Monday, April 04, 2005 4:45 PM
Subject: Re: Rebel floor
I stopped my floor at D and that left me enough room
to instal my ELT under
the elevator cables.
At 03:01 PM 4/4/2005 -0400, you wrote:
Hi guys,
Still working on my cabin floor. I was wondering if
I'm suppose to install
the floor between bulkheads D and E. That is
directly behind the elevator
pulleys. My tailcone floor piece ends at the pulleys
(bulkhead D) but the
instructions say to install inner corner wraps
between D and E but say
nothing about the small trapezoidal floor piece
required behind the pulleys.
Since I'll probably mount my ELT and battery back
there I guess I'll go
ahead and install the floor back to E. (I'll STILL
have 2 extra wraps)
Is everyone doing it this way? Any reason not to?
Thanks Much!
Joel Jacobs
Rebel 416
Subaru EJ-22
List archives located at:
https://www.dcsol.com/login?mode=HTML
WALTER KLATT
Post by WALTER KLATT » Sat Feb 18, 2012 1:23 pm
I guess I should look at a map, but I thought you were up north there somewhere in the boonies. Of course you can come down to Guelph, too.
Date: Tuesday, April 5, 2005 7:30 am
Subject: Walter's trip to Ontario
[mike.davis@dcsol.com]On Behalf Of
At 03:01 PM 4/4/2005 -0400, you wrote: I'm suppose to install directly behind the elevator (bulkhead D) but the between D and E but say required behind the pulleys. there I guess I'll go have 2 extra wraps) ----------- https://www.dcsol.com/login?mode=HTML -----------
I can do from here to Toronto's Pearson Terminal #3 in 1hr-10 minutes if
someone is going to miss their flight! Generally should take 1hr-45 if you
do the speed limit though and miss all the traffic.
Sent: Tuesday, April 05, 2005 11:10 AM
Subject: Re: Walter's trip to Ontario
