I am about to skin the upper tank on my first wing and am a little concerned
about the sequence - Since it has the 3500 gusset on top that comes back to
the 1st stringer behind the main spar it seems like a tall order to get the
tank closed in one session including the leading edge, gusset and tank skin
Alternative #1 - Setting all rivets except from fwd stringer forward and
clecoing everything forward till the proseal sets up. Then finish out the
leading edge -
Alternative #2 - set the leading edge including the gusset - except from the
main spar fwd about five rivets so I can slip the tank skin under later with
my proseal bead and then include all of the tank rivets at once.
Leaning towards #2
Seems like the manual figures on setting the tank skin and pressure testing,
then drill out the rivets and set the leading edge/gusset.
I can't believe that the upper skin stringer dams will come out pro - O-well
cross my fingers and plunge forward.
Britt - SR194
3500 Upper Wing Tankskin
Scott Aldrich
Is anyone else at this stage on a 3500 kit built wing?? Seems it isn't
spelled out too well due to most either being a retrofit of a 2500 wing or
fast build.
No response from MAM on how they are doing it at the factory??
Scott
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Reed
Britt Civ OO-ALC/MADE
Sent: Monday, March 14, 2005 4:25 PM
To: 'rebel-builders@dcsol.com'
Subject: 3500 Upper Wing Tankskin
leading edge -
Leaning towards #2
Britt - SR194
fast build.
Scott
leading edge -
Leaning towards #2
Britt - SR194
Sorry Scott, I'm one of the ones that gets to compromise a perfectly good
pressure tested set of tanks to do those .063 spar backer skins....if I ever
find time to get back on the Moose.
If you don't think you can hit it in one shot...the holes that you can't
rivet without the upper doubler in place put a cleco in EVERY hole until the
PRC sets up so nothing shifts. Then pull all the clecos, clean any teats off
around the holes (BY HAND NO SOLVENTS!) and then coat that doubler and rivet
it down being sure to roll every rivet in proseal so it bonds in with the
stuff that has set.
If you have someone helping you and only doing a tank at a time I would
think you can get it all down in one shot. Rob Helt and myself did BOTH of
his SR top tank skins at the same time in only a few hours without any
problems. If you only tackled one at a time it would be very similar.
Sent: Monday, March 14, 2005 9:35 PM
Subject: RE: 3500 Upper Wing Tankskin
stuff that has set.
concernedIs anyone else at this stage on a 3500 kit built wing?? Seems it isn't
fast build.
Scott
toabout the sequence - Since it has the 3500 gusset on top that comes back
thethe 1st stringer behind the main spar it seems like a tall order to get
skintank closed in one session including the leading edge, gusset and tank
theAlternative #1 - Setting all rivets except from fwd stringer forward and
leading edge -
withmain spar fwd about five rivets so I can slip the tank skin under later
testing,my proseal bead and then include all of the tank rivets at once.
Leaning towards #2
O-wellthen drill out the rivets and set the leading edge/gusset.
Britt - SR194
Reed Britt Civ OO-ALC/MAD
Wayne - Thanks for the response - I have kind of asked before and it seems
like it is under everyone else's radar -
On your project with Rob Helt did you do the leading edge at the same time??
Thanks again --
I Searched the archives for references to the ".063 spar backer skins" with
no success - what are you talking about?
Britt SR194
G. O'Shea
Sent: Monday, March 14, 2005 7:55 PM
Subject: Re: 3500 Upper Wing Tankskin
stuff that has set.
Thanks again --
Britt SR194
G. O'Shea
stuff that has set.
fast build.
Scott
leading edge -
Leaning towards #2
Britt - SR194
Scott Aldrich
Britt, I believe he is referring to what you called the gusset, which is
part W-711 double. (I think)
Scott
Sent: Tuesday, March 15, 2005 7:41 AM
Thanks again --
Britt SR194
G. O'Shea
stuff that has set.
Scott
Thanks again --
Britt SR194
G. O'Shea
stuff that has set.
fast build.
Scott
leading edge -
Leaning towards #2
Britt - SR194
You call it a gusset, I call it a spar backer plate...no different than all
the ones for the stab and vertical rear fin post!
Britt, I don't think there is anyone on here that has done the 3500 wings
from scratch! (that weren't 2500's to start out)
Yes leading edge down and sealed all at the same time...only way I see that
makes sense to do it......well I guess you could do the cleco in every hole
trick there as well!
Will send you a pic direct of the 2500 tanks done,
From: "Reed Britt Civ OO-ALC/MADE" <Britt.REED@HILL.af.mil>
Sent: Tuesday, March 15, 2005 9:40 AM
time??Wayne - Thanks for the response - I have kind of asked before and it seems
withThanks again --
Wayneno success - what are you talking about?
Britt SR194
everG. O'Shea
thefind time to get back on the Moose.
offPRC sets up so nothing shifts. Then pull all the clecos, clean any teats
rivetaround the holes (BY HAND NO SOLVENTS!) and then coat that doubler and
orit down being sure to roll every rivet in proseal so it bonds in with the
stuff that has set.
Reedfast build.
Scott
theconcernedBritt Civ OO-ALC/MADE
I am about to skin the upper tank on my first wing and am a littletoabout the sequence - Since it has the 3500 gusset on top that comes backthethe 1st stringer behind the main spar it seems like a tall order to getskintank closed in one session including the leading edge, gusset and tankAlternative #1 - Setting all rivets except from fwd stringer forward and
theleading edge -
Alternative #2 - set the leading edge including the gusset - except fromwithmain spar fwd about five rivets so I can slip the tank skin under latertesting,my proseal bead and then include all of the tank rivets at once.
Leaning towards #2
Seems like the manual figures on setting the tank skin and pressureO-wellthen drill out the rivets and set the leading edge/gusset.
I can't believe that the upper skin stringer dams will come out pro -cross my fingers and plunge forward.
Britt - SR194
