hi all
i am assembling my parts order and need to know the post sizes that are on
the battery and starter contactors so i can get the right ring terminals,
thanx
mike#007
terminal sizes
terminal sizes
My contactors are all 5/16". Don't know about aircraft starters.
hi all
thanx
mike#007
terminal sizes
Oh yes and I think the contactor coil terminals were #8.
And a couple of things like the Bussman fuse blocks had #10 bolts.
Brass internal tooth lockwashers can be had from Rona/Building Box but
in this area the only Rona that stocked them was the one at 401 and
Winston Churchill.
Winston Churchill.
hi all
thanx
mike#007
terminal sizes
Hi Mike
My battery uses 3/16", master solenoid 1/4", most switch and CB contacts are
#8, but I've ordered up 5 of each size to make sure I had some in stock for
all other jobs that come along, and I'll order up loads of #8 for when I
start on the panel.
Nigel
745E
Jones, Michael
Sent: 14 March 2005 15:10
To: Rebel-Builders EMIAL (E-mail)
Subject: terminal sizes
hi all
thanx
mike#007
start on the panel.
Nigel
745E
Jones, Michael
hi all
thanx
mike#007
