trim servo mounting
trim servo mounting
Post by Ralph Baker » Sat Feb 18, 2012 1:09 pm
Mike, we mounted ours on a rectangular plate that had a slight curve to
match the elevator surface. The servo mounted to the plate and then the
plate was attached via nutplates to the elevator. This was done for
maintenance ease and no sealant used. Plan now how you will run the
electric feed and think about how to replace that wiring if it failed.
We ran a small aluminum tube as a wire way in the elevator. Suggest
"sleeving" the all thread that connects the servo and trim tab with
aluminum tubing for appearance and rigidity.
mbetti
trim servo mounting
Post by mbetti » Sat Feb 18, 2012 1:09 pm
On that subject, where abouts does the wire exit the elevator to go to the fuselage? or stab?
David Ricker
trim servo mounting
Post by David Ricker » Sat Feb 18, 2012 1:09 pm
We ran the wires out through a hole in the front spar of the elevator via a grommet and it will
go up to the fuselage under or over the fin (I think, we haven't gotten that far yet). I would
cover the wires with heat shrink as they go up to the fuselage.
David A. Ricker
Fall River, Nova Scotia
Canada
Mike Betti
trim servo mounting
Post by Mike Betti » Sat Feb 18, 2012 1:09 pm
Would it come out by the control horns/center hinge of the elevator?
Mike Betti
771E
Sent: Friday, February 04, 2005 7:23 PM
Subject: Re: trim servo mounting
David A. Ricker
Canada
David Ricker
trim servo mounting
Yep, that's exactly it.
Mike Betti
771E
David A. Ricker
Canada
David A. Ricker
Canada
