Width of Moose on floats
Ryan Mowat
Post by Ryan Mowat » Sat Feb 18, 2012 9:40 am
I have trailered the plane on a 9'6" low deck semi truck and it just
sticks out each side, so I'd say 10' about max width and centerline is
about 9'
Ryan Mowat, P.Eng.
30528 1A Greatnorthern Ave
Abbotsford, BC V2T 6H4
(604) 556-7222 (ext 307), (604) 556-7215 (Fax)
Sent: Tuesday, November 02, 2004 2:12 PM
Subject: Re: What's your favourite way to dock/ramp your floatplane??
Al and/or Ryan...what is the center to center width for the keel strips
total overall outside to outside width of your floats?
Knowing that... then I won't have too narrow of a ramp for you when you
arrive...or if I ever get off my ass and pull my Moose back out of the
marine container....finish it and mount those EDO 3500's I have for it
...that are collecting dust.
Sent: Monday, November 01, 2004 8:10 PM
Hi Ryan,
Welcome to the list.
Al
Sent: Monday, November 01, 2004 4:59 PM
Subject: RE: What's your favourite way to dock/ramp your floatplane??
This is the first time I've responded to the email list as I've just
signed up, however the float docking question is of interest to me.
have only about 150 hours on a 400 hp Moose with amphibs so I must
say
the safest place is in the hanger. But on the lake I have found
that a
good Buoy and a couple of 45 gallon plastic drums work fairly well.
Tie
two 25' lines from the float tips to the buoy and a rope from each
wing
to a mostly submerged plastic drum. The plane is free to rotate 360
degrees around the buoy as the wind changes but side gusts are muted
by
the plastic drums. This is how I do it now, but I always worry
about
it. Out of the water would be a better sleep.
Ryan Mowat
List archives located at: https://www.dcsol.com/
Post by Wayne G. O'Shea » Sat Feb 18, 2012 9:40 am
Okay, thanks! Sounds narrow though. Rebel is 8' center to center and about
10' overall width since floats are about 24" wide each...but then again it
has a wider stance than say a C172 or cub so maybe yours are mounted closer
to the certified world. Needs to be a least 2 ' difference between your
center to center distance and your overall width though.
Sent: Tuesday, November 02, 2004 6:31 PM
Subject: Width of Moose on floats
about 9'
Ryan Mowat, P.Eng.
Hi Ryan,
Al
say
that a
Tie
wing
by
about
Ryan Mowat
Ryan Mowat
The actual width of the floats - Montana 3500 Amphib.
Center Line - 8'2"
Max Width - 11' 1"
Ryan Mowat
Thanks Ryan!
Those #'s make more sense and gives me some good numbers to make sure the
ramp is wide enough to have some "pilot error" margin built in!
Sent: Wednesday, November 03, 2004 11:54 AM
Subject: RE: Width of Moose on floats
Center Line - 8'2"
Max Width - 11' 1"
Ryan Mowat
Don Boardman
Post by Don Boardman » Sat Feb 18, 2012 9:40 am
Hi Gang,
Wayne I know you were looking for some installed float dimensions for the
Moose. Ryan sent you some numbers for Keith's floats. I misplaced his
numbers so I don't know if mine are redundant or not.
Measured my Aerocet's yesterday.
Keel to Keel 102"
Outside to Outside 133"
Catch you later,
Don B.
about 9'
Ryan Mowat, P.Eng.
Thanks Don..the more #'s I have... the more I can be sure that everything
and everyone will be able to dock/ramp on our Island, on Lake Temagami.
Sent: Saturday, November 13, 2004 11:18 AM
Subject: Re: Width of Moose on floats
Hi Gang,
Keel to Keel 102"
Catch you later,
Don B.
about 9'
Ryan Mowat, P.Eng.
