Ivoprop to Britt Reid
larry173
Post by larry173 » Sat Feb 18, 2012 12:31 pm
Sent: Tuesday, October 05, 2004 10:29 AM
Subject: Re: Ivoprop
Hi Britt
.Tried to send you an email but seems that you use a GPS connection.So I'll
try to contact you this way I see you are installing a V8 in your Moose I
am planning to install one in mine as well. Have looked around for quite a
while now and was wondering how you are doing yours EG. PSRU engine mount
etc.You could send me an email directly so we are not tying up the chat.
From: "Reed Britt Civ OO-ALC/MADE" <Britt.REED@HILL.af.mil>
Sent: Monday, October 04, 2004 10:56 AM
Subject: RE: Ivoprop
I talked to the folks at Ivoprop and they will not sell you an Ivoprop
if
you are running a Lycoming/Continental etc - The lower frequency more
intense power pulses cause the composite blades to flex/whip - I think
that
is why certified aircraft props cost/weigh more - tougher design
criteria
I am planning on a Ivoprop 3 blade 84" Magnum - square tip swampboat
prop
on
a 8 cylinder chevy 350/LS1 with PSRU
Britt SR194
List archives located at:
